connection cable 3-pin plug to 3-pin plug with speedometer signal 32cm
  • 81116
  • 4049469118419
  • 0,005 kg
€1.98 *
Content: 32 Zentimeter (€6.19 * / 100 Zentimeter)
This cable is intended for transferring data e.g. from fans or a pump to the mainboard or a... more
This cable is intended for transferring data e.g. from fans or a pump to the mainboard or a readout board such as the Heatmaster, T-Balancer or the Aquaero.
Socket to socket is the solution here! All 3 wires supply the device not only with power, but also with the necessary pulse data!
Technical details:
Connection. 2x 3Pin socket
Length: 32cm
1x connection cable 3Pin to 3Pin with speedometer signal
Hersteller: Aquatuning
Made in: Deutschland/Niedersachsen
1st page: 1x 3Pin
2nd page: 1x 3Pin
Design: Extension
Sleeving: Without
€1.48 *
€6.99 *
Alphacool HardTube 16/13mm Acrylic (PMMA) Clear 80cm - Set of 4 (320cm)
€26.98 *
38%
Alphacool Core 1 Aurora Black
€119.98 *
Alphacool Y-Splitter 4-Pin to 3x 4-Pin PWM 60cm
€4.38 *
Content 2 Stück (€15.99 * / 1 Stück)
Alphacool EPDM Tube 16/10 - Black 3m (9.84ft) Retailbox
€6.49 * €8.98 *
Alphacool hose AlphaTube HF 5/3 - Ultra Clear 1m sold by the meter
€2.98 *
€5.48 *
83%
Alphacool Y-cable RGBW 5-pin to 3x 5-pin incl. connector - black 30cm
Content 30 Zentimeter (€3.30 * / 100 Zentimeter)
€0.99 * €5.89 *
