Alphacool Core Geforce RTX 5080 Phoenix with Backplate
- Article no.: 10288
- EAN: 4250197102889
- Weight: 1,229 kg
*1Alphacool introduces its new series of graphics card water coolers for the latest Nvidia GeForce RTX generation. Part of the Core product series, these coolers combine the highest quality with exceptional performance. Thanks to an optimized technical design, these GPU coolers deliver outstanding cooling performance.
- Gainward GeForce RTX™ 5070 Ti Phoenix
- Gainward GeForce RTX™ 5080 Phoenix
| Technical data cooler | |
| Dimensions total (L x W x H) | 182x 125,95 x 34,19mm |
| Material terminal | Nylon |
| Pressure tested | 0,8 bar |
| Threads | 4 x G1/4" |
| Number of digital aRGB LEDs | 7 |
| Color | transparent |
| Dimensions (L x W x H) | 182 x 97,50 x 6mm |
| Thickness backplate without spacers | 3mm |
| Material | Aluminium |
