Alphacool Core RX 9070 XT Red Devil with Backplate
  • 14781
  • 4250197147811
  • 1,453 kg
€219.98 *
S13 Alphacool HardTube 13/10mm Acrylic (PMMA) Clear 80cm
€7.98*
€37.98*
€35.98*
13886 Alphacool Core 1 LT Aurora Acrylic
€84.98*
Alphacool introduces its new series of graphics card water coolers for the latest AMD Radeon RX... more
Alphacool introduces its new series of graphics card water coolers for the latest AMD Radeon RX generation. Part of the Core product series, these coolers combine the highest quality with exceptional performance. Thanks to an optimized technical design, these GPU coolers deliver outstanding cooling performance.
The GPU water cooler has been completely overhauled technically. To optimize cooling performance, the distances between the cooler and the components of the PCB were redefined and tested. The water flow was simulated using the most advanced software and verified through practical tests. These extensive tests allowed for improvements to the cooler base and jetplate, ensuring the best possible cooling performance for the new AMD Radeon RX generation.
- PowerColor Red Devil AMD Radeon™ RX 9070 16GB GDDR6 (RX9070 16G-E/OC)
- PowerColor Red Devil AMD Radeon™ RX 9070 XT 16GB GDDR6 (RX9070XT 16G-E/OC)
Technical data cooler
Dimensions total (L x W x H)214,90 x 145,93 x 33,10mm
Material cooler topAcrylic
Material terminalNylon
Max working temperature60°C
Pressure tested0,8 bar
Threads4 x G1/4"
Thickness cooler bottom3,25mm
Thickness cooling fins0,4mm
Distance cooling fins0,4mm
Illuminationdigital aRGB LEDs
Power digital aRGB LEDs5V
Number of digital aRGB LEDs10
Colortransparent
Technical data backplate
Dimensions (L x W x H)214,90 x 117,40 x 6,00mm
MaterialAluminium
€34.98 *
€2.78 *
€2.68 *
€2.28 *
