Alphacool Core RX 9070 XT Hellhound + Pure with Backplate
  • 14782
  • 4250197147828
  • 1,266 kg
€219.98 *
S13 Alphacool HardTube 13/10mm Acrylic (PMMA) Clear 80cm
€7.98*
€37.98*
€35.98*
13886 Alphacool Core 1 LT Aurora Acrylic
€84.98*
Alphacool introduces its new series of graphics card water coolers for the latest AMD Radeon RX... more
Alphacool introduces its new series of graphics card water coolers for the latest AMD Radeon RX generation. Part of the Core product series, these coolers combine the highest quality with exceptional performance. Thanks to an optimized technical design, these GPU coolers deliver outstanding cooling performance.
The GPU water cooler has been completely overhauled technically. To optimize cooling performance, the distances between the cooler and the components of the PCB were redefined and tested. The water flow was simulated using the most advanced software and verified through practical tests. These extensive tests allowed for improvements to the cooler base and jetplate, ensuring the best possible cooling performance for the new AMD Radeon RX generation.
- PowerColor Hellhound AMD Radeon™ RX 9070 16GB GDDR6
- Sapphire PULSE AMD Radeon™ RX 9070 GPU
- Sapphire PURE AMD Radeon™ RX 9070 OC GPU (11349-02-20G)
- PowerColor Hellhound AMD Radeon™ RX 9070 XT 16GB GDDR6
- PowerColor Hellhound Spectral White Radeon RX 9070 XT 16GB GDDR6 (RX9070XT 16G-L/OC/WHITE)
- PowerColor Reaper AMD Radeon™ RX 9070 XT 16GB GDDR6
- Sapphire PULSE AMD Radeon™ RX 9070 XT GPU
- Sapphire PURE AMD Radeon™ RX 9070 XT GPU
Technical data cooler
Dimensions total (L x W x H)197,00 x 127,33 x 33,35mm
Material cooler topAcrylic
Material terminalNylon
Max working temperature60°C
Pressure tested0,8 bar
Threads4 x G1/4"
Thickness cooler bottom3,25mm
Thickness cooling fins0,4mm
Distance cooling fins0,4mm
Illuminationdigital aRGB LEDs
Power digital aRGB LEDs5V
Number of digital aRGB LEDs10
Colortransparent
Technical data backplate
Dimensions (L x W x H)197,00 x 98,80 x 6,00mm
MaterialAluminium
€20.98 *
€37.98 *
€25.98 *
WAC Alphacool Core 1 LT Black
Delivery date: in 2 - 3 weeks
