Alphacool Core RX 9070 XT Aorus Elite with Backplate
- Article no.: 14780
- EAN: 4250197147804
- Weight: 1,428 kg
*1Alphacool introduces its new series of graphics card water coolers for the latest AMD Radeon RX generation. Part of the Core product series, these coolers combine the highest quality with exceptional performance. Thanks to an optimized technical design, these GPU coolers deliver outstanding cooling performance.
The GPU water cooler has been completely overhauled technically. To optimize cooling performance, the distances between the cooler and the components of the PCB were redefined and tested. The water flow was simulated using the most advanced software and verified through practical tests. These extensive tests allowed for improvements to the cooler base and jetplate, ensuring the best possible cooling performance for the new AMD Radeon RX generation.
- Gigabyte AORUS Radeon™ RX 9070 XT ELITE 16G (GV-R9070XTAORUS E-16GD)
- Gigabyte Radeon™ RX 9070 XT GAMING OC 16G (GV-R9070XTGAMING OC-16GD)
| Technical data cooler | |
| Dimensions total (L x W x H) | 224,00 x 139,07 x 33,60mm |
| Material terminal | Nylon |
| Pressure tested | 0,8 bar |
| Threads | 4 x G1/4" |
| Number of digital aRGB LEDs | 10 |
| Color | transparent |
| Dimensions (L x W x H) | 224,00 x 110,50 x 6,00mm |
| Thickness backplate without spacers | 3mm |
| Material | Aluminium |
