B-stock Alphacool Eisblock XPX CPU - Satin Clear Version Version with integrated 13/10mm connection
  • 1017939
  • 4049469263287
  • 0,461 kg
€14.98 * €59.98 * (75.03% Saved)
This is a B-stock item. The cooler features permanently integrated fittings for hoses... more
The cooler features permanently integrated fittings for hoses with a 10 mm inner diameter, which cannot be replaced. Mounting hardware is not included.
For further information, please refer to item 1013722.
Gebrauchte Ware
Base: AMD AM3(+);AMD AM4;Intel 775;Intel 1150/1151/1155/1156;Intel 1366;Intel 2011(-3);Intel 2066;
Dimensions (L x W x H: 63 x 73 x 14mm
Connection: 2x G1/4"
Material base plate: Copper
Material Lid: Carbon fiber;
60%
WACZ Alphacool Aurora XPX RGB Frame - Black PHT EOL
€3.99 * €9.95 *
86%
Hint!
AGZ Alphacool Aurora LED Ring 50mm - Blau EOL
Alphacool Aurora LED Ring 50mm - blue
€2.09 * €14.79 *
63%
€1.58 * €4.28 *
Alphacool Y-Splitter 4-Pin to 3x 4-Pin PWM 15cm
€2.78 *
33%
KOI Alphacool Core Ocean T38 AIO 420mm
€59.98 * €89.98 *
38%
KOI Alphacool Core Ocean T38 AIO 280mm
€47.98 * €76.98 *
44%
KOI Alphacool Core Ocean T38 AIO 120mm
€29.98 * €53.98 *
60%
WACZ Alphacool Aurora XPX RGB Frame - Chrome PHT EOL
€3.99 * €9.95 *
86%
KAB Alphacool Y-Kabel RGBW 5pol auf 3x 5pol inkl. Stecker - Schwarz 60cm EOL
Alphacool Y-cable RGBW 5-pin to 3x 5-pin incl. connector - black 60cm
Content 60 Zentimeter (€1.65 * / 100 Zentimeter)
€0.99 * €6.89 *
Content 10 Stück (€1.40 * / 1 Stück)
