Alphacool Core Storm 420mm XT45 water cooling Set
  • 11991
  • 4250197119917
  • 6,66 kg
  • There are more than 5 units available
€209.98 * €349.98 * (40% Saved)
€59.98*
SEN Alphacool Eisfluegel Aurora flow indicator "HighFlow" with speedometer signal
€36.98*
SEN Alphacool temperature sensor Square Acetal
€15.98*
ANS Alphacool Eiszapfen 13/10mm screw-on nozzle 90° rotatable G1/4 - 4pcs Set Chrome
€31.98*
13096 Alphacool Apex Thermal grease 20g
€46.98*
WAK Alphacool Eisblock Aurora Acryl GPX-N RTX 4090 Founders Edition with backplate PHT EOL
€69.98*
€6.98*
With the Core Storm water cooling kit, Alphacool provides all the components needed to get... more
With the Core Storm water cooling kit, Alphacool provides all the components needed to get started in the world of water cooling. The set is aimed not only at beginners, but also at enthusiasts. The selected components are optimally matched and come from Alphacool's DIY program. The choice of materials is still uncompromisingly based on copper or brass for all metals in order to guarantee performance-oriented CPU cooling. Due to the included quick-release fastener, additional components like radiators or GPU coolers can be integrated afterwards without having to drain or rebuild the water loop.
Eisblock XPX Aurora CPU Cooler
Alphacool's Eisblock XPX Aurora CPU water cooler offers the highest performance and impresses with its outstanding quality. The patented ramp system ensures optimal water flow within the cooler as water is forced evenly through the jet plate. 81 cooling fins are distributed on the CPU cooler base, occupying an area of 34 x 32mm and thus accommodating the ever-growing CPU DIEs. The Aurora design in combination with the 15 addressable digital aRGB LEDs provides many options for outstanding CPU water cooler illumination. The included mounting hardware makes the CPU cooler compatible with popular mainstream sockets from AMD and Intel.
Core 100 Aurora Reservoir & VPP Apex Pump
The Core reservoir combines performance with design. The reservoir tube is made of acrylic, while the D5/VPP pump top and lid are made of acetal. The combination of these two materials gives the expansion tank a subtle appearance. The wow effect is provided by 12 digitally addressable RGB LEDs in the pump top and the Lighttower water effect inside the acrylic tube. The Apex VPP is a powerful pump that is compatible with the most popular D5/VPP tops and reservoirs. The pump's speed can be read out via the 4-pin fan connector and controlled via PWM signal. The Apex VPP is supplied with power via a SATA connector.
NexXxoS XT45 Full Copper 420mm Radiator V.2
All water-bearing parts and the cooling fins are made of pure copper. Thus, the NexXxoS XT45 achieves the highest thermal conductivity value of all radiators on the market and can easily dissipate extremely high waste heat. The radiator has two IN or OUT connections with G1/4" threads in the pre-chamber area. On the opposite side is a fill or vent port, which can be used to fill and drain the water loop.
Rise Aurora 140mm fans
The fans can be controlled from 0 to 2000 rpm via the 4-pin PWM connector. At 800 rpm, the fan is nearly silent, but still offers good airflow (154.1 m3/h) coupled with high static pressure (2.20 mm/H2O). In addition to a wide control range, the Rise fan also offers superior digital aRGB lighting. The frame and hub feature 24 digitally addressable 5V RGB LEDs that illuminate the entire fan.
AlphaTube HF 13/10mm tubing & HF G1/4" quick connect coupling
The clear 13/10mm hose made of PVC offers comfortable handling when routing and connecting water cooling components. It has good routing and kinking characteristics and allows uncomplicated bridging of tight bend radii. The HF quick-connect coupling included in the scope of delivery allows easy integration of further components at a later date without having to drain or rebuild the water loop.
Eiszapfen 13/10mm G1/4" Connections
Thermal Paste & Coolant
All cables (aRGB, PWM) and controllers needed to use & control the pump, fan and aRGB lighting are included. The accessory package also includes important tools like hose cutter, filling bottle and an ATX 24-pin jumper. Thus, the construction of the custom loop can be started "out-of-the-box" immediately.
Intel: 775 / 1056 / 1155 / 1150 / 1151 / 1200 / 1700 / 2011 / 2011-3 / 2066 / 1851
Technical data CPU cooler
Dimensions (L x W x H)75,8 x 75,8 x 33mm
Material coolernickel-plated copper
Material housingnylon, acrylic
Threads2 x G1/4“
Illumination3-Pin 5V, 15 digital aRGB LEDs
Max working temperature60°C
Pressure tested0,8 Bar
Technical data reservoir
Dimensions (L x W x H)131 x 76,5 x 76,5mm
Capacity200 ml
Material Pump top & coveracetal
Material tubeacrylic
Threads3x G1/4“ IT
Illumination3-Pin 5V, 12 digital aRGB LEDs
Technical data pump
Dimensions (L x W x H)65 x 65 x 41mm
Materialsynthetic material, aluminium, ceramics
Threads4-Pin PWM | SATA
Starting voltage12V DC
Maximum pumping head4,25m
Maximum flow rate340L/h
Technical data radiator
Dimensions (L x W x H)455,5 x 144 x 45mm (+/- 3%)
Material threadsbrass
Threads4x G1/4" IN/OUT & 1x Fill-/Drainport G1/4"
Possible fan size140mm
Possible fan assembly3x one-sided / 6x both-sided
Fin density12
Technical data fan
Dimensions (L x W x H)140 x 140 x 25mm
Speed0 - 2000 RPM (+/- 10%)
Threads4-Pin PWM
Voltage12V DC
Current consumption6,6 Watt (max)
Static pressure2,20 mm/H2O
Max. air flow154,1 m³/h
Noisemax. 38,4 dB(A)
Speedometer signalyes
Auto-Restartyes
Illumination3-Pin 5V, 24 digital aRGB LEDs, 3.5W
Technical data tube
Dimensions (outer/inner)13/10mm
MaterialPVC
Length3m
Colorclear
Technical data 13/10mm G1/4" fittings
Materialbrass
Threads1x G1/4" OT | 1x tube connection 13/10mm
Technical data quick release coupling
Dimensions (L x D)60,3 x 26,1mm
Threads2x G1/4“ IT
Technical data coolant
Ingredientsosmose water(93,8%), glysofor L (4,2%), RHOBA KLA (2%)
Boiling point105°C
Freezing point-10°C
Packaging unit1L bottle
Colorclear (not UV-active)
Technical thermal grease
Viscosity (mPa. s)3.000.000
Specific Gravity (g/cm³)2,7
Thermal Conductivity (w/m-K)16
Temperature Stability (Degree Celcius)-50 ~ 200
Colorgray
Radiator dimensions: 455,5 x 144 x 45mm
Radiator thickness: 39 - 49mm
Radiator size: 420mm
Hose dimensions: 13/10mm
Base: AMD AM3(+);AMD AM4;AMD AM5;Intel 115x;Intel 2011(-3);Intel LGA 1200;Intel LGA 1700;Intel LGA 1851;
Prefilled: No
11%
€15.98 * €17.98 *
Alphacool Y-Splitter 4-Pin to 3x 4-Pin PWM 60cm
€4.38 *
€2.68 *
22%
€46.98 * €59.98 *
Alphacool Y-cable RGB 4-pin to 3x 4-pin incl. connector - black 60cm
€2.98 *
€33.98 *
63%
€1.58 * €4.28 *
€99.98 *
Delivery date: in 3 - 4 days
Alphacool Y-Splitter aRGB 3-Pin to 4x 3-Pin 30cm
€5.99 *
€2.78 *
Alphacool fan cable 4-pin to 4-pin extension 30cm
€2.28 *
33%
€5.99 * €8.98 *
Alphacool Apex Liquid Red UV-active 1000ml
Content 2 Stück (€12.99 * / 1 Stück)
€25.98 *
12%
WAC Alphacool Eisbaer Aurora (Solo) - Digital RGB
€65.99 * €74.98 *
€1.48 *
