NVIDIA 40 Series Thermal Pad Replacement set
  • 1025723
  • 4049469341305
  • 0,108 kg
Pads included: 1mm Pads: 1x 8x115mm 2x 15x51mm 1x 15x15mm 1x 15x42mm 3x 8x100mm 1x 8x15mm... more
Pads included:
1mm Pads:
1x 8x115mm
2x 15x51mm
1x 15x15mm
1x 15x42mm
3x 8x100mm
1x 8x15mm
2x 8x110mm
4x 8x8mm
2mm Pads:
2x 8x84mm
3mm Pads:
1x 45x45mm (hole in the middle)
2x 15x51mm
1x 15x40mm
1x 15x15mm
1x 8x115mm
4x 8x100mm
1x 8x20mm
1x 8x40mm
Made in: China
€6.49 * €8.98 *
WACZ Alphacool Core AM5 Performance Kit
€21.98 *
Delivery date: in 8 - 9 days
WZS Spritzflasche 250ml PE-LD
spray bottle 250ml PE-LD
€3.59 *
AGB Alphacool Core 140mm Reservoir mit VPP/D5 Pumpe
Alphacool Core 140mm Reservoir with VPP/D5 Apex PWM Pump
€178.98 *
