Alphacool Eisschicht Ultra Soft thermal pad 3W/mk 100x100x1,5mm
  • 13455
  • 4250197134552
  • 0,01 kg
€15.78 * €24.98 * (36.83% Saved)
Content: 100 cm² (€0.16 * / 1 cm²)
12856 Alphacool Eisschicht Light thermal pad - 7W/mK 100x100x0,5mm
€5.38*
12859 Alphacool Eisschicht Light thermal pad - 7W/mK 100x100x1,5mm
€8.48*
13009 Alphacool Subzero Thermal grease 20g
€33.97*
€4.28*
The Eisschicht Ultra Soft are Alphacool's performance oriented solution in the range of thermal... more
The Eisschicht Ultra Soft are Alphacool's performance oriented solution in the range of thermal pads. Due to their outstanding properties, they can almost be compared to a thermal paste. These Ultra Soft thermal pads nestle much better to components, which contributes to a significant improvement in cooling performance.
The material of the Ultra Soft thermal pads acts similar to a thermal paste. While normal thermal pads are only pressed together by the contact pressure there can be areas that are uneven due to different high components, making them less effective. With the ultra soft Eisschicht this problem doesn’t exist because the material distributes itself similar to thermal paste and thus prevents the highest components from being subjected to increased contact pressure by the cooler. As standard thermal pads are quite stiff they can also cause too much pressure on components. In the worst cases, this can cause the PCB to bend and even break. Due to the soft consistency of the Ultra Soft Eisschicht any excess material can spread out rather than cause problems. The Ultra Soft Eisschicht is not only performance orientated, but also safer!
But this is not the only advantage!
Moreover, the special material cannot dry out. Usually the silicone in thermal pads bleeds out over time. This makes them hard and the performance of the pads drops rapidly from a certain point. This is not the case with the Ultra Soft Eisschicht. They can be used over a much longer period of time without significantly losing performance.
A thermal pad with fabric?
The consistency of the heat conducting material is similar to a viscous heat conducting paste. A special fabric is embedded so that the material remains stable and can be used as a thermal pad. This ensures a perfect distribution of the material if the element to be cooled has an uneven shape. Examples include voltage transformers, VRam and similar electronic components of all kinds that require cooling.
Cutting? No problem!
To cut the thermal pads to size, you should definitely leave the foil on the pads. So the pads can easily be cut to size with a pair of scissors. This is just as easy as cutting paper. The cut edges remain perfectly clean and do not fray.
L x W x H100 x 100 x 1,5mm
Specific Gravitiy ASTM D2972,65 g/cc
Thermal Conductivity ASTM D54703.0 W/mK
Hardness ASTM 224020 Shore 00
Working temperature40 to 200°C
Outgassing ASTM E5950,40% TML
Volume Resistivity ASTM D2576.2X10 high 13 Ohm-meter
Dielectric Constant ASTM D1505,5 MHz
Dielectric Breakdown Voltage ASTM D149>5000 VAC
Flame Rating UL E33110094 V0
Colorwhite
37%
WÄM Alphacool Eisschicht Ultra Soft Wärmeleitpad 3W/mk 100x100x1mm
Alphacool Eisschicht Ultra Soft thermal pad 3W/mk 100x100x1mm
€12.58 * €19.98 *
46%
WÄM Alphacool Eisschicht Ultra Soft Wärmeleitpad 3W/mk 50x50x3mm
Alphacool Eisschicht Ultra Soft thermal pad 3W/mk 50x50x3mm
Content 25 cm² (€0.22 * / 1 cm²)
€5.38 * €9.98 *
61%
€5.78 * €14.98 *
€6.49 * €8.98 *
€0.99 *
€38.98 *
Alphacool Core double sided adhesive thermal pad 100x100x0.25mm
Content 100 cm² (€0.07 * / 1 cm²)
€6.99 *
24%
Alphacool Core Thermal Pad Soft 6.2W/mk 40x40x0,5mm
Content 16 cm² (€0.24 * / 1 cm²)
€3.78 * €4.97 *
€2.68 *
47%
€15.78 * €29.98 *
38%
WÄM Alphacool Rise Ultra Soft Wärmeleitpad 7W/mk 50x50x3mm
Content 25 cm² (€0.20 * / 1 cm²)
€4.97 * €7.98 *
62%
WÄM Alphacool Rise Ultra Soft Wärmeleitpad 7W/mk 100x100x0,5mm
Content 100 cm² (€0.05 * / 1 cm²)
€4.88 * €12.98 *
Alphacool ES Orbiter 360 TS
€549.98 *
Delivery date: in 10 - 11 weeks
6%
€16.98 * €17.98 *
€25.98 *
Alphacool Eiszapfen 14mm HardTube screw-on nozzle G1/4 - Deep Black Sixpack
€34.98 *
