Alphacool Core Thermal Pad Soft 9W/mk 40x40x3mm
  • 13424
  • 4250197134248
  • 0,03 kg
€7.68 * €12.98 * (40.83% Saved)
Content: 16 cm² (€0.48 * / 1 cm²)
€4.28*
€69.98*
13419 Alphacool Core Thermal Pad Soft 9W/mk 100x100x3mm
€27.98*
13421 Alphacool Core Thermal Pad Soft 9W/mk 40x40x1mm
€4.78*
13427 Alphacool Core Thermal Pad Soft 9W/mk 120x20x1,5mm
€6.99*
Alphacool's performance thermal pad can be used to cool electronic components of all kinds where... more
Increased service life!
Versatile use!
Technical data thermal pad
Dimensions (L x W x H)40 x 40 x 3mm
Thermal Conductivity (ASTM D5470)9.0 W/mK (±10%)
Hardness (ASTM D2240)50 (Shore 00) (±15)
Working temperature-50 to ~180°C
Volume Resistance (ASTM D257)1×10¹² Ohm-m
Dielectric Breakdown Voltage (ASTM D149)≥8 KV/mm
Density (ASTM D792)3.2 g/cm³ (±10%)
Elongation (ASTM D412)40%
Flame Rating (UL 94)V-0
Colorpink
43%
€3.97 * €6.99 *
38%
Alphacool Core Thermal Pad Soft 9W/mk 40x40x2mm
Content 16 cm² (€0.39 * / 1 cm²)
€6.18 * €9.98 *
Alphacool Core Thermal Pad Soft 9W/mk 40x40x1,5mm
Content 16 cm² (€0.35 * / 1 cm²)
€5.58 * €7.98 *
49%
Alphacool Core Thermal Pad Soft 9W/mk 100x100x2mm
Content 100 cm² (€0.19 * / 1 cm²)
€18.78 * €36.99 *
38%
WÄM Alphacool Rise Ultra Soft Wärmeleitpad 7W/mk 50x50x3mm
Content 25 cm² (€0.20 * / 1 cm²)
€4.97 * €7.98 *
32%
Alphacool Apex Thermal Pad Soft 18W/mk 120x20x1,5mm
Content 24 cm² (€1.41 * / 1 cm²)
€33.88 * €49.98 *
WAC Alphacool Core 1 Silver
42%
Content 24 cm² (€0.29 * / 1 cm²)
€6.99 * €11.98 *
32%
WÄM Alphacool Core Wärmeleitpad Soft 9W/mk 40x40x1mm
Content 16 cm² (€0.30 * / 1 cm²)
€4.78 * €6.99 *
45%
Alphacool Core Thermal Pad Soft 9W/mk 100x100x1,5mm
€16.48 * €29.98 *
Alphacool Core Thermal Pad Soft 6.2W/mk 120x20x1,5mm
Content 24 cm² (€0.23 * / 1 cm²)
€5.58 * €7.98 *
Alphacool Core Thermal Pad Soft 6.2W/mk 40x40x1mm
Content 16 cm² (€0.22 * / 1 cm²)
€3.58 * €4.97 *
50%
Alphacool Apex Soft thermal pad 11W/mk 2x 120x20x1mm
Content 48 cm² (€0.20 * / 1 cm²)
€9.58 * €18.98 *
47%
€15.78 * €29.98 *
21%
€33.97 * €42.98 *
€83.98 *
Delivery date: in 6 - 7 weeks
35%
WÄM Alphacool Eisschicht Light Wärmeleitpad - 7W/mK 100x100x1,5mm PHT EOL
Alphacool Eisschicht Light thermal pad - 7W/mK 100x100x1,5mm
Content 100 cm² (€0.08 * / 1 cm²)
€8.48 * €12.98 *
33%
WÄM Alphacool Eisschicht Light Wärmeleitpad - 7W/mK 100x100x0,5mm PHT EOL
Alphacool Eisschicht Light thermal pad - 7W/mK 100x100x0,5mm
Content 100 cm² (€0.05 * / 1 cm²)
€5.38 * €7.98 *
Alphacool GPU RAM Copper Heatsinks 6.5x6.5mm - 10 pcs.
Content 10 Stück (€1.00 * / 1 Stück)
31%
WÄM Alphacool Eisschicht Wärmeleitpad - 11W/mK 120x20x1,5mm - 2 Stück PHT EOL
Content 48 cm² (€0.41 * / 1 cm²)
€19.88 * €28.98 *
35%
WÄM Alphacool Eisschicht Wärmeleitpad - 11W/mK 120x20x1mm - 2 Stück PHT EOL
Content 48 cm² (€0.30 * / 1 cm²)
€14.38 * €21.98 *
