Alphacool Ice Layer Thermal Pad - 14W/mK 100x100x1mm
  • 12459
  • 4250197124591
  • 0,059 kg
  • Currently there are 5 available
€54.78 * €79.98 * (31.51% Saved)
Content: 100 cm² (€0.55 * / 1 cm²)
€0.98 *
€1.19 *
WÄM Alphacool Eisschicht Wärmeleitpad - 14W/mK 100x100x0,5mm PHT EOL
Alphacool Ice Layer Thermal Pad - 14W/mK 100x100x0.5mm
Content 100 cm² (€0.33 * / 1 cm²)
€32.88 * €46.98 *
Content 100 cm² (€0.86 * / 1 cm²)
€86.28 * €119.98 *
€6.49 * €8.98 *
45%
Content 100 cm² (€0.18 * / 1 cm²)
€17.98 * €32.97 *
€1.89 *
€38.98 *
WAC Alphacool Core 1 Silver
44%
Alphacool Core Thermal Pad Soft 9W/mk 100x100x3mm
Content 100 cm² (€0.28 * / 1 cm²)
€27.98 * €49.98 *
€3.47 *
Alphacool extension JST aRGB 3-pin to 3-pin 15cm
Content 15 Zentimeter (€8.60 * / 100 Zentimeter)
€1.29 *
€2.28 *
€2.78 *
21%
€33.97 * €42.98 *
