Alphacool thermal pad for NexXxoS GPX 3W/mk 15x15x3mm yellow marked PE Bag (24 pieces)
- Article no.: 12195
- EAN: 4250197121958
- Weight: 0,044 kg
Alphacool's new thermal pads with 3W/mk
Area of application:
- Graphics card ram cooler
- Mainboard voltage converter
- North and/or Southbridge thanks to the excellent thermal conductivity
- Color: grey
- Dimensions (L x W x H): 15 x 15 x 3mm
- Thermal conductivity: 3W/mk
- electrically non-conductive
Scope of delivery
- 24x Alphacool thermal pad for NexXxoS GPX
