Alphacool thermal pad for NexXxoS GPX 3W/mk 15x15x1.5mm red marked PE Bag (24 pieces)
- Article no.: 12193
- EAN: 4250197121934
- Weight: 0,017 kg
Alphacool's new thermal pads with 3W/mk
Area of application:
Graphics card ram cooler
Mainboard voltage converter
North and/or Southbridge thanks to the excellent thermal conductivity
Color: grey
Dimensions (L x W x H): 15 x 15 x 1.5mm
Thermal conductivity: 3W/mk
electrically non-conductive
Scope of delivery
24x Alphacool thermal pad for NexXxoS GPX
Fastening: | Slightly adhesive |
Thickness: | 1,5mm |
Surface dimensions: | 15 x 15mm |
Thermal conductivity: | 3,0W/mk |
Liefertermin: in 2 - 3 Wochen
