Alphacool thermal pad for NexXxoS GPX 3W/mk 15x15x1.5mm red marked PE Bag (24 pieces)
  • 12193
  • 4250197121934
  • 0,017 kg
€3.18 *
Content: 54 cm² (€0.06 * / 1 cm²)
Area of application:
Graphics card ram cooler
Mainboard voltage converter
North and/or Southbridge thanks to the excellent thermal conductivity
Color: grey
Dimensions (L x W x H): 15 x 15 x 1.5mm
Thermal conductivity: 3W/mk
electrically non-conductive
Scope of delivery
24x Alphacool thermal pad for NexXxoS GPX
Fastening: Slightly adhesive
Thickness: 1,5mm
Surface dimensions: 15 x 15mm
Thermal conductivity: 3,0W/mk
WAC Alphacool Eisbaer Pro ES (Solo) Full Black
€72.99 *
Content 240 Zentimeter (€7.91 * / 100 Zentimeter)
Alphacool Core thermal pad Soft 6.2W/mk 40x40x0.5mm
Content 16 cm² (€0.25 * / 1 cm²)
€3.97 *
Alphacool Ice Layer Ultra Soft Thermal Pad 3W/mk 100x100x1.5mm
€24.98 *
€1.89 *
17%
S16 Alphacool Carbon HardTube 16mm 4x 80cm
Content 80 Zentimeter (€43.71 * / 100 Zentimeter)
€34.97 * €42.00 *
Alphacool Apex Soft thermal pad 11W/mk 2x 120x20x1mm
Content 48 cm² (€0.40 * / 1 cm²)
€29.98 *
Alphacool Rise Ultra Soft thermal pad 7W/mk 100x100x0.5mm
WZS Alphacool ES Big Inline Partikelfilter 2x G1/4" IG
Alphacool ES Big Inline Particle Filter 2x G1/4" IG
€29.98 *
17%
€14.98 * €17.98 *
22%
S16 Alphacool Schlauch AlphaTube HF 16/10 (3/8"ID) - UV Blau 3m (9,8ft) Retailbox 300cm
Alphacool hose AlphaTube HF 16/10 (3/8"ID) - UV blue 3m (9.8ft) retail box 300cm
€13.98 * €17.98 *
WAGZ Alphacool Eisblock Aurora Terminal flat straight - Acetal
€34.98 *
