  • 13096
  • 4250197130967
  • 0,03 kg
€46.98 * €59.98 * (21.67% Saved)
Content: 20 Gramm (€2,349.00 * / 1000 Gramm)
€59.98*
ZSO Alphacool antistatic wrist cuff blue
€4.48*
13013 Alphacool Rise Ultra Soft thermal pad 7W/mk 50x50x3mm
€7.98*
13014 Alphacool Rise Ultra Soft thermal pad 7W/mk 50x50x2mm
€6.99*
13098 Alphacool Apex Thermal grease 100g
€122.97*
The Alphacool Apex Thermal Grease is intended for all users who want to achieve the optimum... more
Application
Properties
Alphacool's Apex Thermal Grease has an extremely high thermal conductivity, making it one of the best performing thermal pastes on the market. Only liquid metal thermal pastes offer better thermal conductivity. The Apex Thermal Grease is delivered in a 20g container with screw cap. The amount of thermal paste is sufficient for several applications and can be stored in the container protected from drying out. In addition, Apex Thermal Grease is non-conductive and non-caustic. If a small amount of paste is spilled during application, damage to the hardware is highly unlikely.
Range of uses
Volatilization Rate (24H@200°C)%less than 0.5
Density (g/cc)3.2 (Test method ASTM D792)
Viscosity (mPa.s)150~200*10³ (Test method ASTM D2196)
Continuous Using Temperature (°C)-40°C to 120°C
Breakdown Voltage (V/mil)250 (Test method ASTM D149)
Thermal Impedance (°C in 2/W)0.1 +/- 0.01 (Test method ASTM D5470)
Max. working pressure (psi)40
Colorgray
Quantity20g
Contents: 20 - 39g
Viscosity: 150~200*10³
Density: 3,2 g/cm³
Color: Gray
Safety notes
  • Rinse gently with water for a few minutes.
  • In case of fire: Do not inhale explosion and fire gases.
€1.89 *
WÄM Alphacool Apex 17W/mK Thermal grease 50g
Content 50 Gramm (€1,399.60 * / 1000 Gramm)
€69.98 *
WÄM Alphacool Apex 17W/mK Thermal grease 100g
Content 100 Gramm (€1,229.70 * / 1000 Gramm)
€122.97 *
Alphacool Silver Grease 0.5g
€1.19 *
WZS Spritzflasche 500ml PE-LD
spray bottle 500ml PE-LD
€4.19 *
Alphacool Y-Splitter aRGB 3-Pin to 4x 3-Pin 60cm
€6.99 *
Content 6 Stück (€2.16 * / 1 Stück)
€65.99 *
€6.49 * €8.98 *
Content 320 Zentimeter (€7.81 * / 100 Zentimeter)
€24.98 *
WAK Alphacool Core Geforce RTX 5090 ROG Astral mit Backplate
Alphacool Core Geforce RTX 5090 ROG Astral with backplate
€199.98 *
WÄM Alphacool Apex Wärmeleitpad Soft 16W/mk 120x20x0,5mm
Alphacool Apex thermal pad Soft 16W/mk 120x20x0.5mm
Content 24 cm² (€0.62 * / 1 cm²)
WÄM Alphacool Apex Wärmeleitpad Soft 18W/mk 100x100x0,5mm
Alphacool Apex thermal pad Soft 18W/mk 100x100x0.5mm
Content 100 cm² (€0.60 * / 1 cm²)
€59.98 *
S16 Alphacool EPDM Tube 16/10 - Black 1m (3,28ft) Retailbox
Alphacool EPDM Tube 16/10 - Black 1m (3.28ft) Retailbox
Alphacool Y-Splitter aRGB 3-Pin to 4x 3-Pin 30cm
€5.99 *
Alphacool Y-Splitter aRGB 3-Pin to 4x 3-Pin 15cm
€5.68 *
Alphacool Y-Splitter 4-Pin to 4x 4-Pin PWM 60cm
€5.28 *
Alphacool Y-Splitter 4-Pin to 4x 4-Pin PWM 30cm
Alphacool Y-Splitter 4-Pin to 4x 4-Pin PWM 15cm
€3.47 *
Alphacool Y-Splitter 4-Pin to 3x 4-Pin PWM 30cm
€3.47 *
Alphacool Y-Splitter 4-Pin to 2x 4-Pin PWM 30cm
€2.68 *
€2.68 *
Alphacool fan cable 4-pin to 4-pin extension 15cm
€1.98 *
Alphacool EPDM Tube 13/10 - Black 1m (3.28ft) Retailbox
Liefertermin: in 7 - 8 Wochen
Content 2 Stück (€14.99 * / 1 Stück)
€29.98 *
Alphacool Eiszapfen screw plug G1/4 - 6pcs Set Chrome
Alphacool Eiszapfen angle adapter 90° rotatable G1/4 AG to G1/4 IG - 4pcs Set Chrome
Content 4 Stück (€6.25 * / 1 Stück)
€24.98 *
Alphacool Eiszapfen 16/10mm screw-on nozzle 90° rotatable G1/4 - 4pcs Set Chrome
Content 4 Stück (€7.00 * / 1 Stück)
€27.98 *
23%
KOI Alphacool Core Ocean T38 AIO 240mm
€49.98 * €64.99 *
