Alphacool Eisdecke Laing DDC Acetal attachment V.2
- Article no.: 13185
- EAN: 4250197131858
- Weight: 0,338 kg
The tried and tested Laing DDC attachment is now available in a new version.
This attachment has been a benchmark for years. Small improvements have been made time and again. The first major update differs in a few details, both visually and technically.
The principle: On the bottom there is space for the Laing DDC pump, which is separate from the original attachment, and the inlet and outlet at the front or on the top.
For even more flexibility, the ice cover has three inlets and two outlets. Another feature is the new bracket to give the whole unit a stable stand and round off the overall visual appearance. Optional installation in a 3.5" slot is still possible.
The attachment can be converted into a complete expansion tank using the expansion tank attachment available as an accessory, which has also been redesigned.
Technical data:
- Dimensions: 80 x 80 x 23mm
- Material: Acetal
- Connections: 5x 1/4" thread
- 1x Alphacool Eisdecke Laing DDC Acetal attachment V.2
- 3x locking screw 1/4"
- 2x feet
- Mounting material
Note on assembly: After assembly, a small gap remains between the pump and the cover. The seal is ensured because the O-ring forms a positive connection here. Therefore, do not tighten the screws too tightly, as this can cause damage to the cover.
