Alphacool Ice Comb X14 - 3mm black - 4 pieces
- Article no.: 24755
- EAN: 4250197247559
- Weight: 0,001 kg
What is that?
Highlights
- Nylon is flexible and cannot break
- Easy installation without modifications
- Simple and clean laying of cables
- Material: Polyester
- Variant: X14 Flat
- Dimensions: 30.5 x 8 x 2mm
- Color: Black
Scope of delivery
- Alphacool Eiskamm X14 Flat - 3mm black - 4 pieces
Delivery date: in 3 - 4 days
Delivery date: in 12 - 13 weeks
