Alphacool Power Button Body - Chrome
  • 17429
  • 4250197174299
  • 0,116 kg
KAB Alphacool power button/push button connection cable - black 200cm
€2.98*
The world-famous water cooling manufacturer Alphacool offers a simple solution with the... more
The world-famous water cooling manufacturer Alphacool offers a simple solution with the Powerbutton Body to start your PC quickly and easily. Most computers are positioned under or on the side of the desk. In this position, the start button is usually difficult to reach. In the area of modding, start buttons are also usually positioned differently than usual.
All you need is a vandalism switch with a 19 mm thread. The extensive selection of vandalism switches gives you the freedom to design your own. You also need a suitable cable that you can connect to the switch and your mainboard. We naturally recommend the Alphacool power button/push button connection cable with a length of 2 or 3 m.
  • Dimensions
    Diameter base: 50mm
    Tower diameter: 45mm
    Height: 49mm
    Hole for button: 19mm
  • Material: aluminum
  • Color: Chrome
Scope of delivery
  • 1x Alphacool Power Button Body - Chrome
  • Instructions
75%
€0.99 * €3.89 *
€0.99 *
€2.98 *
€25.98 *
56%
€1.98 * €4.47 *
56%
€1.98 * €4.47 *
56%
MKA Alphacool AlphaCord Sleeve 4mm - 3,3m (10ft) - Black (Paracord 550 Typ 3) 330cm EOL
Alphacool AlphaCord Sleeve 4mm - 3.3m (10ft) - Black (Paracord 550 Type 3) 330cm
€1.98 * €4.47 *
ANS Alphacool Eiszapfen 19/13mm Anschraubtülle G1/4 - Chrome Sixpack PHT EOL
Alphacool Eiszapfen 19/13mm screw-on nozzle G1/4 - Chrome Sixpack
€33.98 *
ANS Alphacool Eiszapfen 19/13mm Anschraubtülle G1/4 - Deep Black Sixpack PHT EOL
Alphacool Eiszapfen 19/13mm screw-on nozzle G1/4 - Deep Black Sixpack
€33.98 *
Alphacool hose AlphaTube HF 13/10 (3/8"ID) - UV Green 3m (9.8ft) Retailbox 300cm
