Alphacool ice case - circular feeder large
- Article no.: 90352
- EAN: 4250197136884
- Weight: 0,08 kg
Circular arc feeder
Large version
Pipes with a diameter of 13 or 12 mm are bent to a radius of 33.5 mm, pipes with a diameter of 16 mm are bent to a radius of 32 mm
Do not bend the pipe beyond an angle of 180° so that it can be removed again once it has cooled down.
All bending guides and stops are designed for pipe diameters of 12 or 13 mm and 16 mm. The required guide is always aligned downwards.
Liefertermin: in 8 - 9 Wochen
