Alphacool Core Geforce RTX 5080 Gamerock + Phantom with backplate
- Article no.: 10260
- EAN: 4250197102605
- Weight: 1,54 kg
Delivery date: in 8 - 9 weeks
- Gainward GeForce RTX™ 5070 Ti Phantom (NE7507T019T2-GB2030P)
- Palit GeForce RTX™ 5070 Ti GameRock (NE7507T019T2-GB2030G)
- Palit GeForce RTX™ 5070 Ti GameRock OC (NE7507TH19T2-GB2030G)
- Gainward GeForce RTX™ 5080 Phantom (4915 / NE75080019T2-GB2030P)
- Gainward GeForce RTX™ 5080 Phantom GS (4908 / NE75080T19T2-GB2030P)
- Palit GeForce RTX™ 5080 GameRock (NE75080019T2-GB2030G)
- Palit GeForce RTX™ 5080 GameRock OC (NE75080T19T2-GB2030G)
Technical data cooler | |
Dimensions total (L x W x H) | 173,50 x 154,03 x 34,07mm |
Material cooler top | Acrylic |
Material terminal | Nylon |
Material Connection thread | Brass |
Pressure tested | 0,8 bar |
Threads | 4 x G1/4" |
Thickness cooler bottom | 3,25mm |
Illumination | digital aRGB LEDs |
Number of digital aRGB LEDs | 8 |
Color | transparent |
Technical data backplate | |
Dimensions (L x W x H) | 173,50 x 154,03 x 6mm |
Thickness backplate without spacers | 3mm |
Material | Aluminium |
Material base plate: | Aluminum |
Dimensions: | 173.50 x 154.03 x 34.07mm |
Connection: | 4x G1/4" |
Hardware manufacturers: | NVIDIA |
Hardware model: | RTX 5080; |
