Alphacool Core Geforce RTX 4090 Master V.2 with backplate
  • 13837
  • 4250197138376
  • 2,141 kg
€99.98 * €199.98 * (50.01% Saved)
€19.98*
ANK Alphacool HF quick release coupling set TPV - Eisbaer compatible - Black
€12.98*
€18.98*
13446 Alphacool Core 1 Aurora Black
€125.98*
Alphacool's Core product series is characterized by high quality, outstanding performance and... more
Note: This Version (V.2) of the cooler is compatible with PCB Layout V.1.1
- Gigabyte AORUS GeForce RTX 4090 Master 24G, 24GB GDDR6X (GV-N4090AORUS M-24GD)
- Gigabyte GeForce RTX 4090 Gaming OC 24G, 24GB GDDR6X (GV-N4090GAMING OC-24GD)
Technical data cooler
Dimensions (L x W x H)235,80 x 152,96 x 31,90mm
Material cooler topacrylic
Max working temperature60°C
Pressure tested0,8 bar
Threads4 x G1/4"
Thickness cooler bottom11,3mm
Thickness cooling fins0,4mm
Distance cooling fins0,4mm
Illuminationdigital aRGB LEDs
Power digital aRGB LEDs5V
Number of digital aRGB LEDs13
Colortransparent
Technical data backplate
Dimensions (L x W x H)235,80 x 129,96 x 5mm
Materialaluminium
Awards & Videos
Delivery date: in 8 - 9 days
€34.98 *
€5.99 *
€25.98 *
Delivery date: in 3 - 4 month
