Alphacool Eisblock Aurora Acrylic GPX-N RTX 3090 TI Suprim X with backplate
  • 13085
  • 4250197130851
  • 1,82 kg
€77.98 * €159.98 * (51.26% Saved)
€19.98*
€29.98*
€15.98*
14436 Alphacool NexXxoS HPE-20 Full Copper 240mm Radiator
€78.98*
The Alphacool Eisblock Aurora Acryl GPX graphics card water cooler with backplate combines style... more
The Alphacool Eisblock Aurora Acryl GPX graphics card water cooler with backplate combines style with performance. Extreme cooling performance and extensive digital RGB lighting are what set it apart. Experience and technical know-how from more than a decade have gone into the development, without making any technical compromises. The Eisblock Aurora Acryl GPX is a major development of the previous Alphacool graphics card water cooler, which has been improved in every area.
More performance!
When developing the Eisblock Aurora Acryl GPX graphics card water cooler, emphasis was naturally placed on increasing performance. In the first step, the cooler was brought closer to the individual components by reducing the thickness of the thermal pads. In the second step, the nickel-plated copper block was also made thinner. Step 3 involves the constant optimization of the water flow within the cooler. Result: All important components such as voltage converters and RAM are cooled much better and more effectively by the water and the cooling performance increases significantly.
Brilliant design!
The addressable digital aRGB LEDs are embedded directly in the cooling block and run along the sides of the entire cooling block. The effect is lighting that encloses the entire cooling block. No corner or edge remains unlit by the aRGB LEDs. The new design is more angular, with all edges bevelled. The result is better light scattering in the water cooler due to the reflections on these bevels. They also create various contours that give the Eisblock Aurora Acryl GPX cooler a very unique visual touch.
Copper or aluminum?
Alphacool only uses copper in its water coolers. The Eisblock Aurora Acryl GPX has nickel-plated copper. Compared to previous models, Alphacool has improved the type of nickel plating, which has significantly increased acid resistance. This should prevent the nickel plating from flaking off. Why does Alphacool use copper instead of aluminum? Copper has almost twice the thermal conductivity of aluminum and is therefore clearly the better material for water cooling.
Other special features
The Eisblock Aurora Acrylic GPX GPU cooler has patented locking screws that sit flush with the surface of the terminal. The Alphacool logo is in the corner on the top and is also fully illuminated. The corresponding designations of the compatible graphics card manufacturers can be seen on the front of the terminal. Of course, these are also fully illuminated by the addressable digital LEDs. IN and OUT are marked by small, discreet triangles. They are easy to recognize and fit perfectly into the overall visual line of the graphics card water cooler.
MSI GeForce RTX 3090 Ti Suprim X 24G, 24GB GDDR6X, HDMI, 3x DP
MSI GeForce RTX 3090 Ti Gaming X Trio 24G, 24GB GDDR6X, HDMI, 3x DP
MSI GeForce RTX 3090 Ti Gaming Trio 24G, 24GB GDDR6X, HDMI, 3x DP
MSI GeForce RTX 3090 Ti Suprim 24G, 24GB GDDR6X, HDMI, 3x DP
Technical data cooler
L x W x H 266x153x24mm
Radiator base material nickel-plated copper
Material radiator top Acrylic
Connections 4xG1/4
Thick cooling fins 0.6mm
Maximum operating temperature 60°C
lighting 13x digital RGB LEDs
Power connection Digital RGB LEDs 3-Pin JST
Voltage Digital RGB LEDs 5V
Technical data backplate
L x W x H 266x128x6mm
material aluminum
Color black
Made in: China
Cooler type: Complete cooler
Material base plate: Copper;
Material Lid: Acrylic;
SLI compatible: Yes
Dimensions: 266 x 153 x 24mm
Connection: 4x G1/4"
Hardware model: RTX 3090 Ti;
€44.98 *
ANS Alphacool HT 13mm HardTube Anschraubtülle G1/4 - gerändelt - Deep Black Sixpack PHT EOL
Alphacool HT 13mm HardTube screw-on nozzle G1/4 - knurled - Deep Black Sixpack
ANS Alphacool Eiszapfen 16mm HardTube Anschraubtülle 90° drehbar G1/4 für Acryl/Messingrohre - 4pcs Set Deep Black
Alphacool Eiszapfen 16mm HardTube screw-on nozzle 90° rotatable G1/4 for acrylic/brass tubes - 4pcs
€33.98 *
€23.98 *
WZS Spritzflasche 250ml PE-LD
spray bottle 250ml PE-LD
€3.59 *
WZS Spritzflasche 500ml PE-LD
spray bottle 500ml PE-LD
€4.19 *
Alphacool Core 1 Aurora Black
€119.98 *
WAC Alphacool Core 1 White
€109.98 *
WAC Alphacool Core 1 Silver
€99.98 *
Alphacool Eiszapfen screw plug G1/4 - 6pcs Set Chrome
