Alphacool Core 140mm fan PWM 2000rpm (140x140x25mm)
  • 24853
  • 4250197135894
  • 0,204 kg
RAB Alphacool NexXxos fan mounting screw M3 x 35 mm - 4 pieces
€4.48*
€5.98*
26158 Alphacool ES Guardian 4Port Powerfan Hub
€52.98*
Alphacool's Core 140mm is a quiet and efficient fan with a wide control range up to 2000 rpm.... more
Alphacool's Core 140mm is a quiet and efficient fan with a wide control range up to 2000 rpm. The PWM controllable fan is not only suitable as a fan on CPU coolers or radiators. Due to its excellent performance values (throughput & static pressure), it can also be used as a case fan. The hydraulically mounted fan axis is smooth running and enables a long service life as well as quiet operation. If you are looking for a powerful fan without aRGB illumination, you will find it in Alpacool's Core 140mm model!
Connections
The fan is controlled via a 4-pin PWM connector. The cable is 40cm long. This allows the fan to be connected directly to the motherboard or a dedicated controller without the use of additional adapter cables or extensions.
Control range
The fan can be controlled from 0 to 2000 rpm via the 4-pin PWM connector. At maximum speed, it allows an airflow of 103.03 CFM combined with a high static pressure of 2.81 mm/H2O. This makes the fan perfect for mounting on radiators of a water cooling system or for ventilating a case.
Dimension (L x W x H)140 x 140 x 25mm
Materialsynthetic material (PBT UL94V-0)
Bearing Typehydraulic Bearing
Rated VoltageDC 12V
Operating VoltageDC 7-14V
Start-up Voltage7V
Rated Current0.45 (Max: 0.5) A
Rated Power5.4 (Max: 6.0) W
Control Range0 - 2000 rpm ±10%
Max. Air Flow103.03 CFM
Max. Static Pressure2.81 mm/H2O
Noise level38.3 (Max: 40.0) dBA
Life Expectance50000 h at 25 degrees celcius
Connection4-Pin PWM
Speed Control Modevia PWM
Operating Temperature-10~+55 degrees celcius
Other FeaturesTachometer Output, Auto Start, Soft Start, Waterproof Level IP22
€2.78 *
€4.48 *
WAC Alphacool Core 1 Silver
€3.47 *
€3.47 *
33%
KOI Alphacool Core Ocean T38 AIO 420mm
€59.98 * €89.98 *
40%
