Alphacool Eisblock XPX Pro AM4/AM5 mounting kit compact
  • 13001
  • 4250197130011
  • 0,076 kg
Alphacool Eisblock XPX Pro 1U
€99.98*
12950 Alphacool Eisblock XPX Aurora PRO - Acryl Black Digital RGB
€74.98*
12951 Alphacool Eisblock XPX Aurora PRO - Acryl Chrome Digital RGB
€74.98*
12981 Alphacool Eisblock XPX Pro Aurora Light - Acryl
€49.98*
With the Alphacool Eisblock XPX Pro AM4/AM5 mounting kit, all Eisblock XPX Pro CPU water coolers... more
With the Alphacool Eisblock XPX Pro AM4/AM5 mounting kit, all Eisblock XPX Pro CPU water coolers and the Alphacool Eisbaer Pro AIO are now compatible with the AMD AM4/AM5 socket. The Alphacool XPX Pro models and the Eisbaer Aurora Pro CPU AIO water cooler extend beyond the CPU DIE and thus offer optimal cooling performance for all AMD Ryzen processors. Therefore, problems with hotspots are a thing of the past and no longer play a role.
Technical data bracket:
L x W x H: 69 x 100 x 2.5 mm
Net weight: 46 g
Download data sheet PDF: Alphacool Eisblock XPX Pro AM4 mounting kit compact
WZS Spritzflasche 500ml PE-LD
spray bottle 500ml PE-LD
€4.19 *
€6.49 * €8.98 *
WÄM AMD 6000 Series Thermal Pad Replacement set
Alphacool Y-Splitter 4-Pin to 3x 4-Pin PWM 30cm
€3.47 *
Alphacool fan cable 4-pin to 4-pin extension 15cm
€1.98 *
Content 2 Stück (€14.99 * / 1 Stück)
€29.98 *
Alphacool Eiszapfen 16/10mm screw-on nozzle 90° rotatable G1/4 - 4pcs Set Chrome
Content 4 Stück (€7.00 * / 1 Stück)
€27.98 *
Content 24 Stück (€0.29 * / 1 Stück)
€6.99 *
Alphacool hose AlphaTube HF 16/10 (3/8"ID) - Ultra Clear 3m (9.8ft) retail box 300cm
