  • 12960
  • 4250197129602
  • 0,664 kg
€69.98 * €74.98 * (6.67% Saved)
17228 Alphacool Eiszapfen 13/10mm compression fitting G1/4 - deep black sixpack
€35.98*
€35.98*
Build your own AIO water cooling system. Alongside the different prefilled Eisbaer Aurora CPU... more
Build your own AIO water cooling system. Alongside the different prefilled Eisbaer Aurora CPU AIO watercoolers that can be used "Out of the Box", the core of the Eisbaer Aurora is also available as a solo version. With it you can decide how you want to build your water cooling loop and which parts you want to use for it. By using the industry standard G1/4" ports, all fittings from the water cooling sector can be used. This gives you the ability to choose the hose thickness, colour, style, and liquid freely. The Eisbaer Aurora gives you full control.
Pump and cooler
The basis of the pump is the Alphacool DC-LT 2 Ceramic pump which is also available separately. The pump is powerful enough to operate a circuit consisting of a radiator, a CPU block, and a graphics card water cooler. It is incredibly quiet, almost inaudible. The cold plate is made of nickel-plated copper and offers excellent heat transfer. Due to the fine fin structure of the cooler bottom and the optimized water flow, the cooling performance is comparable to the best DIY water coolers on the market. No compromises have been made in terms of performance in favour of other features.
Design and lighting
The Eisbaer Aurora Solo is equipped with addressable digital RGB LEDs. The aRGB LEDs can be connected to any 3-pin 5V connector and controlled easily. The housing is decorated with a polar bear, through which the LEDs shine. Due to the extensive control possibilities of Digital RGB LEDs numerous effects can be displayed.
AMD: AM2 / AM2+ / AM3 / AM3+ / AM4 / AM5 / FM1 / FM2 / FM2+ / sTRX4 / TR4
Technical data pump housing
L x W x H66 x 66 x 69 mm
Material reservoirTransparent Nylon
Threads2x G 1/4
Connection Digital aRGB3-Pin JST + 3-Pin 5 V
Quantity Digital aRGB LED10
Technical data pump
Speed2600 rpm
Voltage6-13.5 V DC
Power consumption3.2 W
Maximum flow rate72 L/h
Maximum head1 m
Other technical data
Net weight223 g
Max working temperature60 °C
Pressure tested0.8 bar
€6.49 * €8.98 *
52%
Hint!
€4.80 * €9.98 *
Delivery date: in 5 - 6 weeks
€39.98 *
20%
€3.97 * €4.97 *
