Alphacool Core 1 Aurora White
  • 13834
  • 4250197138345
  • 0,928 kg
€136.98 *
€31.98*
€38.98*
13470 Alphacool Core Geforce RTX 4090 Founders Edition with Backplate
€69.98*
€22.98*
Alphacool presents the Core 1, a new generation of CPU water cooling. The latest desktop... more
Alphacool presents the Core 1, a new generation of CPU water cooling. The latest desktop processors are continuously becoming more powerful, but also produce more and more waste heat. The Core 1 reliably solves this problem with the help of its entirely new 3D-Jetplate, which is also used in industrial applications. The all-metal CPU water cooler not only impresses with its elegant appearance, but also features a new mounting system that simplifies installation.
The best of new and old
Alphacool brings the best of both worlds together with the Core 1. In addition to the new 3D-Jetplate, Alphacool returns to its roots by using a proven cross-slot technique to distribute coolant evenly across the redesigned cooler base. Inside the cooler, O-rings ensure precise water flow for effective cooling. The Core 1's housing is machined from a high-quality brass block and features nickel-plated connectors. The cooler's copper base, also nickel-plated, has been enlarged to ensure full coverage of large CPUs.
New Mounting System
Core Design
The functional and elegant design is a key element of Alphacool's Core series. The nickel-plated connectors and the discreet contour line stand out from the high-quality brass housing. The rounded corners add the perfect touch to the overall look. The Core 1 is available in various color designs, as well as in discreetly illuminated aRGB Aurora models.
AMD: AM4 / AM5
Intel: LGA 1700 / LGA 1851
Dimensions (L x W x H)72 x 72 x 26,50mm
Material cooler topBrass
Material threadsnickel plated Brass
Threads2 x G1/4“
Power supply Digital RGB3-Pin 5V
Quantity digital aRGB LEDs18
Fin thickness0,4mm
Fin distance0,4mm
Pressure tested0,8 bar
Max working temperature60°C
Weight500g
Colorwhite
Warranty: 5 years
€41.98 *
€38.98 *
€38.98 *
€25.98 *
€28.98 *
€37.98 *
