  • 13015
  • 4250197130158
  • 0,015 kg
€5.99 * €8.98 * (33.3% Saved)
Content: 4 Gramm (€1,497.50 * / 1000 Gramm)
€59.98*
ZSO Alphacool antistatic wrist cuff blue
€4.48*
12960 Alphacool Eisbaer Aurora (Solo) - Digital RGB
€65.99*
€6.49*
WAK Alphacool Eisblock Aurora Acryl GPX-A Radeon RX 6800/6800XT Strix/TUF with Backplate PHT EOL
€69.98*
The Alphacool Rise thermal paste is aimed at all users who want to get the optimum performance... more
The Alphacool Rise thermal paste is aimed at all users who want to get the optimum performance out of their system. With moderate thermal conductivity this electrically non-conductive thermal paste is suitable for high contact pressures and is clearly the favourite when performance and easy application is required.
Application
The application of the Alphacool Rise thermal paste differs from most other thermal pastes due its optimal viscosity. For perfect application of the paste , a plastic spatula (not included in delivery) or similar should be used and a thin film should be applied.
Properties
The Rise thermal paste has a moderate thermal conductivity and is slightly more fluid than other thermal pastes. This helps with the application. The syringe in which the Alphacool Rise thermal paste is delivered has a replaceable screw cap. This prevents it from drying out, as you rarely need the entire 4 grams of paste at once. Furthermore, this thermal paste is not electrically conductive. So if a drop of paste is missed, damage to the hardware is highly unlikely.
Contents4g
Density2,7g/cm
Viscosity850000cps TF
ColorThermal Conductivitysilver/grey
Inhalt: 2 - 3,9g
Farbe: grau
Safety notes
Warning
  • Avoid release to the environment.
  • IF ON SKIN: Wash with plenty of water.
  • IF IN EYES: Rinse cautiously with water for several minutes.
  • In case of fire: Do not inhale vapors.
WÄM Alphacool Silver Grease 30g
Content 30 Gramm (€332.67 * / 1000 Gramm)
WACZ Alphacool Eisberg AM3 Schaubensatz
Alphacool Eisberg AM3 screw set
Content 4 Stück (€0.37 * / 1 Stück)
€1.48 *
€6.49 * €8.98 *
Alphacool Apex Liquid Red UV-active 1000ml
€59.98 *
Alphacool Core thermal pad Soft 6.2W/mk 120x20x1.5mm
Content 24 cm² (€0.33 * / 1 cm²)
Alphacool Core thermal pad Soft 6.2W/mk 40x40x2mm
Content 16 cm² (€0.44 * / 1 cm²)
€6.99 *
WÄM Alphacool Core Wärmeleitpad Soft 6.2W/mk 40x40x1,5mm
Alphacool Core thermal pad Soft 6.2W/mk 40x40x1.5mm
Content 16 cm² (€0.37 * / 1 cm²)
€5.99 *
Alphacool Core thermal pad Soft 6.2W/mk 40x40x1mm
Content 16 cm² (€0.31 * / 1 cm²)
€4.97 *
Alphacool fan cable 4-pin to 4-pin extension 30cm
€2.28 *
Alphacool fan cable 4-pin to 4-pin extension 15cm
€1.98 *
Content 24 Stück (€0.17 * / 1 Stück)
€3.98 *
25%
Content 4 Gramm (€2,995.00 * / 1000 Gramm)
€11.98 * €15.98 *
Content 6 Stück (€6.17 * / 1 Stück)
€36.99 *
SZ Alphacool Silicon Bending Insert 150cm für ID 3/8" / 10mm HardTubes - Blau
Alphacool Silicon Bending Insert 150cm for ID 3/8" / 10mm HardTubes - Blue
Content 150 Zentimeter (€9.32 * / 100 Zentimeter)
KOI Alphacool Eisbaer 360 CPU - Black
€136.98 *
WZS Spritzflasche 250ml PE-LD
spray bottle 250ml PE-LD
€3.59 *
WZS Spritzflasche 500ml PE-LD
spray bottle 500ml PE-LD
€4.19 *
WAC Alphacool Core 1 Aurora White
€129.98 *
15%
