Alphacool Dual 24-pin power supply starter cable (2x24-pin to 1x24-pin)
KAB Alphacool Dual 24-Pin Netzteil Starterkabel (2x24-Pin auf 1x24-Pin)
  • 18732
  • 4250197187329
  • 0,074 kg
€15.98*
KAB Alphacool Digital RGB LED Y-cable 3-way with JST connector - black 60cm
€7.98*
18171 Alphacool Mini USB to Mainboard USB 5-Pin 40cm
€2.98*
Alphacool's Dual 24-pin Power Supply Starter Cable allows for the parallel starting of two power... more
Alphacool's Dual 24-pin Power Supply Starter Cable allows for the parallel starting of two power supplies through the motherboard. This allows for an additional power supply with its own power circuit to be added to the system. This is particularly advantageous in systems with multiple graphics cards. Using the Dual Starter Cable, both power supplies start simultaneously.
Cable length10cm
Cable length (starter cable)20cm
Connection24-Pin ATX (2x24-pin to 1x24-pin)
MaterialPlastic
Weight72g
83%
€1.49 * €8.98 *
€2.98 *
€6.99 *
Alphacool Eisblock XPX Pro 1U
Alphacool fan cable 3-Pin to 3-Pin extension PWM 60cm
€2.48 *
€4.38 *
€2.28 *
€34.98 *
€25.98 *
€26.98 *
