Phobya Y-Kabel 4Pin PWM auf 9x 4Pin PWM - Schwarz 60cm
![LK Phobya Y-Kabel 4Pin PWM auf 9x 4Pin PWM - Schwarz 60cm](https://aquatuning.shop-cdn.com/media/image/ab/c1/2d/1011112_1txXzgThfAlnEW_600x600..jpg)
- Article no.: LK
- EAN: 4049469193386
- Weight: 0,056 kg
A Y-cable to connect 9x4-Pin PWM fans to one 4-Pin PWM connector.
As fan control via the Mainboard with a PWM fan is much more affordable than a fan controller, this cable is perfect to give more flexibility.
The extension cable is sleeved with a black mesh which additionally protects the cable and looks great! This further expands the lifespan of the cable. The ends towards the connectors are fixated with heatshrink for a clean finish.
A white marking on one of the split cables shows from which cable the rpm signal is transmitted.
Sleeving:
The idea behind these cables:
Technical specifications:
Connectors:
1x 4-Pin PWM male
9x 4-Pin PWM female
Colour: Black sleeve, black connectors, black heatshrink
Dimensions: Overall 60cm
Conforms with RoHS
Extent of delivery:
1x Phobya Y-cable 4-Pin PWM to 9x4-Pin PWM 60cm - black
Bauform: | Y-Kabel |
1. Seite: | 1x 4Pin PWM |
Sleeving: | schwarz |
Hersteller: | Phobya |
2. Seite: | 9x 4Pin PWM |
![LK Phobya Verlängerung 3Pin - Schwarz 30cm EOL](https://aquatuning.shop-cdn.com/media/image/1e/f3/7e/81028_1TUhirHLck7yLz_200x200..jpg)
![LK Phobya Verlängerung 3Pin - UV Blau 30cm EOL](https://aquatuning.shop-cdn.com/media/image/0c/58/d0/81030_1mQyy9ZN1UbEYH_200x200..jpg)
![LK Phobya Y-Kabel 3Pin Molex auf 9x 3Pin Molex - Schwarz 60cm EOL](https://aquatuning.shop-cdn.com/media/image/01/66/c6/81049_1ldz6clB4id7j0_200x200..jpg)
![LK Phobya Adapter 3Pin (12V) auf 3Pin (7V) 20cm EOL](https://aquatuning.shop-cdn.com/media/image/e8/c0/28/81067_1U2CudqeNwLq5u_200x200..jpg)
![LK Phobya 4Pin PWM Verlängerung - Schwarz 90cm](https://aquatuning.shop-cdn.com/media/image/bb/58/d6/81134_1LL5rBsrWLnfwo_200x200..jpg)
![LK Phobya Y-Kabel 4Pin PWM auf 4x 4Pin PWM - Schwarz 60cm](https://aquatuning.shop-cdn.com/media/image/25/9d/04/1011110_1Wj6PAymPH3MMp_200x200..jpg)
![ANS Alphacool Eiszapfen 16/10mm Anschraubtülle 90° drehbar G1/4 - 4pcs Set Deep Black](https://aquatuning.shop-cdn.com/media/image/d7/e8/e2/1022487_19nEvBCZPcevCB_200x200..jpg)
![ANS Alphacool Eiszapfen 13/10mm Anschraubtülle 90° drehbar G1/4 - 4pcs Set Deep Black](https://aquatuning.shop-cdn.com/media/image/aa/3d/46/1022485_1DYrNWrtaKb4bh_200x200..jpg)
![RAB Alphacool Radiatorschraube 12x M3x30mm/M3x5mm Grau Kreuzschlitz Flachkopf](https://aquatuning.shop-cdn.com/media/image/ce/42/16/1022282_1jgErHOZ4nfK2o_200x200..jpg)
![WÄM Alphacool Apex 17W/mK Thermal grease 4g](https://aquatuning.shop-cdn.com/media/image/2b/b5/16/1022240_1gxSgfGrdtkDJV_200x200..jpg)
![S16 Alphacool EPDM Tube 16/10 - Black 3m (9,84ft) Retailbox](https://aquatuning.shop-cdn.com/media/image/ff/71/84/1021503_1Bs1yo9o5BbZhJ_200x200..jpg)
![S13 Alphacool EPDM Tube 13/10 - Black 3m (9,84ft) Retailbox](https://aquatuning.shop-cdn.com/media/image/6c/ae/02/1021502_01_200x200..jpg)
![S16 Alphacool Schlauch AlphaTube HF 16/10 (3/8"ID) - Ultra Clear 1m (3,3ft) Retailbox 100cm](https://aquatuning.shop-cdn.com/media/image/8f/22/d7/1019549_1JJZc89PFAi8xA_200x200..jpg)
![S16 Alphacool Schlauch AlphaTube TPV 16/10 - Black Matte 3,3m (10ft) Retailbox 330cm](https://aquatuning.shop-cdn.com/media/image/ae/df/fd/1019445_1gbTGjTF6LuC2i_200x200..jpg)
![ANK Alphacool Eiszapfen Schnellverschluss Stecker G1/4 AG - Deep Black](https://aquatuning.shop-cdn.com/media/image/1f/c9/34/1015607_1_200x200..jpg)
Liefertermin: in 5 - 6 Tagen
