connection cable 3-pin plug to 3-pin plug with speedometer signal 32cm
- Article no.: 81116
- EAN: 4049469118419
- Weight: 0,005 kg
This cable is intended for transferring data e.g. from fans or a pump to the mainboard or a readout board such as the Heatmaster, T-Balancer or the Aquaero.
Socket to socket is the solution here! All 3 wires supply the device not only with power, but also with the necessary pulse data!
Technical details:
Connection. 2x 3Pin socket
Length: 32cm
1x connection cable 3Pin to 3Pin with speedometer signal
Hersteller: | Aquatuning |
1st page: | 1x 3Pin |
2nd page: | 1x 3Pin |
Design: | Extension |
Sleeving: | Without |
