Phobya 2pin cable extension socket/plug - 30cm
- Article no.: ZK
- EAN: 4049469081096
- Weight: 0,019 kg
This 2-pin extension is required for sensors that are too far away from the mainboard or reading device. Especially with large housings or if you want to lay the cables out of sight, it is difficult to manage without an extension.
Of course, this extension can also be used for other areas. For example, for the speaker on the housing or the reset or power button.
Technical details:
Connectors: 2 pin to 2 pole extension
Color: black
Dimensions: 30cm
RoHS compliant
1x Phobya 2pin cable extension socket/plug - 30cm
![ZK Phobya 2pin-Kabel Verlängerung Buchse/Stecker 30cm - Schwarz](https://aquatuning.shop-cdn.com/media/image/b8/ef/04/82394_1G42Bm0B0yupr5_200x200..jpg)
![ZK Phobya 2pin-Kabel Verlängerung Buchse/Stecker 60cm - Schwarz](https://aquatuning.shop-cdn.com/media/image/c7/f9/cf/82395_1htpdMgr639sYa_200x200..jpg)
![LK Alphacool Lüfterkabel 4-Pin auf 4-Pin Verlängerung 60cm](https://aquatuning.shop-cdn.com/media/image/57/f8/20/1023108_01_200x200..jpg)
![LK Phobya Verlängerung 3Pin - Schwarz 30cm EOL](https://aquatuning.shop-cdn.com/media/image/1e/f3/7e/81028_1TUhirHLck7yLz_200x200..jpg)
![WAK Alphacool Eisblock Aurora Geforce RTX 4070 TI TUF Gaming mit Backplate](https://aquatuning.shop-cdn.com/media/image/19/22/6d/1023904_1_200x200..jpg)
![WÄM Alphacool Apex Wärmeleitpad Soft 18W/mk 100x100x1,5mm](https://aquatuning.shop-cdn.com/media/image/47/8d/42/1023418_1p1YpwoX3zMHeL_200x200..jpg)
![WÄM Alphacool Apex Wärmeleitpad Soft 18W/mk 100x100x1mm](https://aquatuning.shop-cdn.com/media/image/09/d6/16/1023417_1DvllxMOwAsKQg_200x200..jpg)
![WÄM Alphacool Apex Wärmeleitpad Soft 18W/mk 100x100x0,5mm](https://aquatuning.shop-cdn.com/media/image/83/46/ae/1023416_1MBmW8MHBJuuDo_200x200..jpg)
![LK Alphacool Lüfterkabel 3-Pin auf 3-Pin Verlängerung 15cm](https://aquatuning.shop-cdn.com/media/image/2d/b5/99/1023118_01E6abZUqlEvrK9_200x200..jpg)
![ANF Alphacool Eiszapfen L-Verbinder drehbar G1/4 AG auf G1/4 IG - 4pcs Set Chrome](https://aquatuning.shop-cdn.com/media/image/dc/30/b9/1022490_17XfWL7FRwAIhi_200x200..jpg)
![S16 Alphacool EPDM Tube 16/10 - Black 3m (9,84ft) Retailbox](https://aquatuning.shop-cdn.com/media/image/ff/71/84/1021503_1Bs1yo9o5BbZhJ_200x200..jpg)
![WÄM Alphacool Core 2-Komponenten Wärmeleitkleber 5g](https://aquatuning.shop-cdn.com/media/image/b7/3b/bc/1020421_1GzEv7f1cJuFeO_200x200..jpg)
![S19 Alphacool Schlauch AlphaTube HF 19/13 (1/2"ID) - Ultra Clear 3m (9,8ft) "Retail Package" 300cm](https://aquatuning.shop-cdn.com/media/image/4e/e8/b0/1019558_1kwn4Zilwv9uxV_200x200..jpg)
![S13 Alphacool Schlauch AlphaTube HF 13/10 (3/8"ID) - UV Weiß 3m (9,8ft) Retailbox 300cm](https://aquatuning.shop-cdn.com/media/image/07/7c/cf/1019553_1atF2B7w1ZzxAa_200x200..jpg)
![S11 Alphacool Schlauch AlphaTube HF 11/8 (5/16"ID) - Ultra Clear 3m (9,8ft) "Retail Package" 300cm](https://aquatuning.shop-cdn.com/media/image/d7/a7/86/1019545_1wlLggbeXQGOjh_200x200..jpg)
![ANS Alphacool HF Anschraubtülle TPV Metall - 12,7/7,6mm Gerade - Black - 6er Kit](https://aquatuning.shop-cdn.com/media/image/54/43/08/1016782_1_200x200..jpg)
![ANS Alphacool HF Anschraubtülle TPV - 12,7/7,6mm Gerade - Black - 6er Kit](https://aquatuning.shop-cdn.com/media/image/40/31/87/1016781_1_200x200..jpg)
![KAB Alphacool Verbindungskabel 3Pin auf 3pol Digital RGB - 15cm](https://aquatuning.shop-cdn.com/media/image/d1/63/fe/1016647_1_200x200..png)
![S16 Alphacool Schlauch AlphaTube HF 16/10 (3/8"ID) - Klar 3m (9,8ft) Retailbox 300cm](https://aquatuning.shop-cdn.com/media/image/4c/f6/1c/1015268_1_200x200..jpg)
![WAZ Alphacool Eiswasser Crystal Clear UV-aktiv Fertiggemisch 1000ml](https://aquatuning.shop-cdn.com/media/image/04/f2/94/1014015_1ffEoyajvsWc15_200x200..jpg)
![KAB Alphacool Y-Kabel RGB 4pol auf 3x 4pol inkl. Stecker - Schwarz 30cm](https://aquatuning.shop-cdn.com/media/image/5c/61/96/1013984_101DDl0D3Lrcrs_200x200..jpg)
