Alphacool D5-Pump VPP655 PWM (Bulk wihtout Package and O-Ring)
  • 94259
  • 4049469175481
  • 0,248 kg
€89.99 *
Alphacool's new power pump series, exceptional performance at an unbeatable price. The 12V pumps... more
Alphacool's new power pump series, exceptional performance at an unbeatable price. The 12V pumps can simply be connected directly to the system PSU and the pump will start with your PC for maximum convenience and safety.
This pump is ideal for PC and other electronics water cooling. The DC pump is equipped with an electronically commutated spherical motor. In a pump with a spherical motor the only moving part is a spherically shaped rotor which in this pump is held in place by a bearing ball made of ultra-hard and wear-resistant ceramic. The spherical bearing of the rotor offers many advantages: For example an increase of bearing play is impossible due to the design, allowing the pump to run quietly and smoothly over its whole lifespan. A separate magnetic shielding of the pump is not needed.
The ball motor design allows efficient operation of the pump in combination with excellent performance. The pump can simply be connected to a 12V Molex connector of the system PSU.
The special feature of this model is the fact that only the pump core itself is shipped. Why pay more for all the things you won't need when using this pump with a third-party pump top?
Note on scope of delivery and O-ring
The pump is supplied without an O-ring and without separate packaging. The matching O-ring is available separately under item number 95068. With compatible Alphacool reservoirs and corresponding Alphacool components, the required O-ring is already included in the scope of delivery. However, if the pump is combined with a product from another manufacturer, the matching O-ring (item no. 95068) must be ordered separately.
Rated voltage range8–24 V DC
Standard voltage12 V DC
Input current1.916 A, maximum 3.0 A
Power consumption23 W
Maximum flow rate1,500 l/h at 0 m head
Maximum head3.70 mH₂O at 0 l/h
Maximum pressure320 kPa / 50 PSI / 3.5 bar
Noise level35 dB(A), maximum 40 dB(A)
Maximum coolant temperature60 °C
Bearing materialCarbon / aluminium oxide ceramic
Impeller materialNylon / PPO
Gasket materialEPDM
Housing materialSteel / nylon / PPO
Power connector4-Pin Molex
PWM/Tachometer signal connector4-Pin JST
Expected service life / MTBF50,000 hours
Weight650 g
Compatible fluidsWater and water-glycol mixtures; other fluids available on request
Dimensions65 × 65 × 57 mm
