Alphacool Core Geforce RTX 5080 EPIC-X with Backplate
  • 14740
  • 4250197147408
  • 1,241 kg
€184.86 *
€105.87*
€30.24*
€11.75*
€31.92*
- PNY GeForce RTX™ 5070 Ti EPIC-X RGB™ Overclocked Triple Fan Plus (VCG5071T16TFXXPB1-O)
- PNY GeForce RTX™ 5080 ARGB EPIC-X RGB™ Overclocked Triple Fan GPU
- PNY GeForce RTX™ 5080 ARGB EPIC-X RGB™ Triple Fan GPU
- PNY GeForce RTX™ 5080 Dual-Fan Slim OC (VCG508016DFSXPB1-O)
- PNY GeForce RTX™ 5080 Overclocked Triple Fan GPU
- PNY GeForce RTX™ 5080 Triple Fan GPU
Technical data cooler
Dimensions total (L x W x H)180 x 124,10 x 34,07mm
Material cooler topAcrylic
Material terminalNylon
Max working temperature60°C
Pressure tested0,8 bar
Threads4 x G1/4"
Thickness cooler bottom3,25mm
Thickness cooling fins0,4mm
Distance cooling fins0,4mm
Illuminationdigital aRGB LEDs
Power digital aRGB LEDs5V
Number of digital aRGB LEDs7
Colortransparent
Technical data backplate
Dimensions (L x W x H)180,00 x 95,57 x 6,00mm
MaterialAluminium
WAC Alphacool Core 1 Silver
S16 Alphacool EPDM Tube 16/10 - Schwarz 1m (3,28ft) Retailbox
Alphacool EPDM Tube 16/10 - black 1m (3,28ft) Retailbox
Content 1 Laufende(r) Meter
€5.99 *
€3.47 *
€5.28 *
AGZ Alphacool Core Push Mounting 50mm M3/M4/UNC 6-32 Set 4x
€21.98 *
Content 4 Stück (€5.00 * / 1 Stück)
