Alphacool Core Heat Gun 2000W
- Article no.: 10197
- EAN: 4250197101974
- Weight: 0,841 kg
The Alphacool Core Heat Gun enables the bending of HardTubes. It is simple and versatile. Compared to the Apex version, it is a cheaper alternative that does not have an LCD display.
Easy handling
A switch on the handle allows the air speed of the Core Heat Gun to be regulated in two stages, while a rotary control allows the temperature to be adjusted. The device is designed for use in the hand or when switched off. Three different nozzle attachments for different areas of application are included in the scope of delivery.
Maximum safety
The Alphacool Core Heat Gun has feet that ensure a firm and secure stand, allowing HardTubes to be bent using both hands. The ventilation slots provide overload protection. As a temperature of up to 600°C can be reached, extreme caution is still required.
Technical data | |
Dimensions (L x W x H) | 250 x 75 x 190 mm |
Material | Plastic / metal |
Weight | 520g |
Cable length | 160cm |
Temperature control | 8 levels + Max Power |
Temperature range | 60-600°C |
Wind speed control | 2 levels |
Air Output | 250-500L/min |
Voltage | 230V AC |
Max. power consumption | 2000W |
Frequency | 50/60 Hz |
Operating Temperature | -10°C ~ 40°C |
Storage Temperature | -20°C ~ 65°C |
Relative Humidity | 45% ~ 85% |
Color | blue |
