Alphacool Ice Layer Thermal Pad - 14W/mK 120x20x1mm - 2 pieces
  • 12462
  • 4250197124621
  • 0,04 kg
  • Currently there are 5 available
€32.97 * €49.98 * (34.03% Saved)
Content: 48 cm² (€0.69 * / 1 cm²)
31%
€23.98 * €34.97 *
Content 100 cm² (€0.86 * / 1 cm²)
€86.28 * €119.98 *
€6.49 * €8.98 *
45%
Content 100 cm² (€0.18 * / 1 cm²)
€17.98 * €32.97 *
43%
€3.97 * €6.99 *
61%
€5.78 * €14.98 *
€37.98 *
€1.48 *
SZ Alphacool Silicon Bending Insert 150cm für ID 3/8" / 10mm HardTubes - Blau
Alphacool Silicon Bending Insert 150cm for ID 3/8" / 10mm HardTubes - Blue
Content 150 Zentimeter (€9.32 * / 100 Zentimeter)
31%
WÄM Alphacool Eisschicht Wärmeleitpad - 14W/mK 120x20x1,5mm - 2 Stück PHT EOL
Alphacool Ice Layer Thermal Pad - 14W/mK 120x20x1.5mm - 2 pieces
Content 48 cm² (€1.01 * / 1 cm²)
€48.48 * €69.98 *
