Alphacool Ice Layer Thermal Pad - 14W/mK 100x100x0.5mm
- Article no.: 12458
- EAN: 4250197124584
- Weight: 0,04 kg
Fastening: | Slightly adhesive |
Thickness: | 0,5mm |
Surface dimensions: | 100 x 100mm |
Thermal conductivity: | 14W/mk |
