Alphacool Ice Layer Thermal Pad - 11W/mK 100x100x1.5mm
  • 12453
  • 4250197124539
  • 0,08 kg
  • There are more than 5 units available
€49.98 *
Content: 100 cm² (€0.50 * / 1 cm²)
Fastening: Slightly adhesive
Thickness: 1,5mm
Surface dimensions: 100 x 100mm
Thermal conductivity: 11W/mk
WÄM Alphacool Wärmeleitklebepad doppelseitig 100x100x0,5mm EOL
Alphacool thermal adhesive pad double-sided 100x100x0.5mm
Content 100 cm² (€0.04 * / 1 cm²)
€3.97 *
€1.19 *
WÄM Alphacool Wärmeleitklebepad doppelseitig 120x20x0,5mm EOL
Alphacool thermal adhesive pad double-sided 120x20x0.5mm
Content 24 cm² (€0.10 * / 1 cm²)
€2.28 *
WAGZ Alphacool Eisschicht Wärmeleitpad - 11W/mK 100x100x1mm EOL
Content 100 cm² (€0.35 * / 1 cm²)
€34.97 *
€29.98 *
Alphacool Core thermal pad Soft 9W/mk 100x100x2mm
Content 100 cm² (€0.37 * / 1 cm²)
€36.99 *
Alphacool Core thermal pad Soft 9W/mk 100x100x3mm
Content 100 cm² (€0.50 * / 1 cm²)
€49.98 *
WAR Alphacool Eisschicht Wärmeleitpad - 11W/mK 120x20x1mm - 2 Stück PHT EOL
€21.98 *
20%
€3.97 * €4.97 *
€6.49 * €8.98 *
WAR Alphacool Eisschicht Wärmeleitpad - 11W/mK 120x20x1,5mm - 2 Stück PHT EOL
Content 48 cm² (€0.60 * / 1 cm²)
€28.98 *
€1.89 *
21%
€33.97 * €42.98 *
€6.99 *
KAB Alphacool Eis-Matrix Verbindungskabel - 10cm EOL
Alphacool Ice Matrix connection cable - 10cm
Content 10 Zentimeter (€9.90 * / 100 Zentimeter)
€0.99 *
€6.99 *
62%
KAB Alphacool Y-Kabel RGB 4pol auf 3x 4pol inkl. Stecker - Schwarz 30cm EOL
Alphacool Y-cable RGB 4-pin to 3x 4-pin incl. connector - black 30cm
Content 30 Zentimeter (€8.27 * / 100 Zentimeter)
€2.48 * €6.49 *
Content 10 Stück (€1.40 * / 1 Stück)
Alphacool GPU RAM Copper Heatsinks 6.5x6.5mm - 10 pcs.
Content 10 Stück (€1.00 * / 1 Stück)
Delivery date: in 2 - 3 weeks
ROH Alphacool Eisbaer GPX Extension Set (Schlauch und Anschlüsse)
Alphacool Eisbaer GPX Extension Set (hose and connections)
€13.19 *
