Alphacool Core Thermal Pad Soft 9W/mk 120x20x1,5mm
  • 13427
  • 4250197134279
  • 0,026 kg
€6.99 * €11.98 * (41.65% Saved)
Content: 24 cm² (€0.29 * / 1 cm²)
€4.28*
€69.98*
13417 Alphacool Core Thermal Pad Soft 9W/mk 100x100x1,5mm
€16.48*
13422 Alphacool Core Thermal Pad Soft 9W/mk 40x40x1,5mm
€5.58*
13426 Alphacool Core Thermal Pad Soft 9W/mk 120x20x1mm
€5.68*
Alphacool's performance thermal pad can be used to cool electronic components of all kinds where... more
Increased service life!
Versatile use!
Technical data thermal pad
Dimensions (L x W x H)120 x 20 x 1,5mm
Thermal Conductivity (ASTM D5470)9.0 W/mK (±10%)
Hardness (ASTM D2240)50 (Shore 00) (±15)
Working temperature-50 to ~180°C
Volume Resistance (ASTM D257)1×10¹² Ohm-m
Dielectric Breakdown Voltage (ASTM D149)≥8 KV/mm
Density (ASTM D792)3.2 g/cm³ (±10%)
Elongation (ASTM D412)40%
Flame Rating (UL 94)V-0
Colorpink
€0.98 *
€1.19 *
43%
Content 24 cm² (€0.24 * / 1 cm²)
€5.68 * €9.98 *
43%
Alphacool Core Thermal Pad Soft 9W/mk 120x20x0,5mm
Content 24 cm² (€0.19 * / 1 cm²)
€4.58 * €7.98 *
38%
Alphacool Core Thermal Pad Soft 9W/mk 40x40x2mm
Content 16 cm² (€0.39 * / 1 cm²)
€6.18 * €9.98 *
48%
Alphacool Core Thermal Pad Soft 6.2W/mk 100x100x2mm
€12.88 * €24.98 *
€1.89 *
43%
€3.97 * €6.99 *
61%
€5.78 * €14.98 *
€6.99 *
Alphacool Core double sided adhesive thermal pad 100x100x0.25mm
Content 100 cm² (€0.07 * / 1 cm²)
€6.99 *
Alphacool 4-Pin Molex to Lumberg 10cm
Content 10 Zentimeter (€44.80 * / 100 Zentimeter)
€4.48 *
WAC Alphacool Core 1 Silver
41%
Alphacool Core Thermal Pad Soft 9W/mk 40x40x3mm
Content 16 cm² (€0.48 * / 1 cm²)
€7.68 * €12.98 *
Content 16 cm² (€0.35 * / 1 cm²)
€5.58 * €7.98 *
32%
WÄM Alphacool Core Wärmeleitpad Soft 9W/mk 40x40x1mm
Alphacool Core Thermal Pad Soft 9W/mk 40x40x1mm
Content 16 cm² (€0.30 * / 1 cm²)
€4.78 * €6.99 *
32%
WÄM Alphacool Core Wärmeleitpad Soft 9W/mk 40x40x0,5mm
Alphacool Core Thermal Pad Soft 9W/mk 40x40x0,5mm
Content 16 cm² (€0.26 * / 1 cm²)
€4.08 * €5.99 *
46%
Alphacool Core Thermal Pad Soft 9W/mk 100x100x1mm
Content 100 cm² (€0.12 * / 1 cm²)
€11.78 * €21.98 *
Alphacool Core Thermal Pad Soft 6.2W/mk 120x20x1,5mm
Content 24 cm² (€0.23 * / 1 cm²)
€5.58 * €7.98 *
33%
Alphacool Core Thermal Pad Soft 6.2W/mk 120x20x1mm
Content 24 cm² (€0.20 * / 1 cm²)
€4.68 * €6.99 *
22%
WÄM Alphacool Core Wärmeleitpad Soft 6.2W/mk 40x40x1,5mm
Alphacool Core Thermal Pad Soft 6.2W/mk 40x40x1,5mm
Content 16 cm² (€0.29 * / 1 cm²)
€4.68 * €5.99 *
Alphacool Core Thermal Pad Soft 6.2W/mk 40x40x1mm
Content 16 cm² (€0.22 * / 1 cm²)
€3.58 * €4.97 *
45%
Content 100 cm² (€0.18 * / 1 cm²)
€17.98 * €32.97 *
43%
Alphacool Core Thermal Pad Soft 6.2W/mk 100x100x0,5mm
€6.88 * €11.98 *
€4.48 *
