Alphacool Core Thermal Pad Soft 6.2W/mk 100x100x1,5mm
  • 13404
  • 4250197134040
  • 0,063 kg
€11.98 * €21.98 * (45.5% Saved)
Content: 100 cm² (€0.12 * / 1 cm²)
€4.28*
€69.98*
13409 Alphacool Core Thermal Pad Soft 6.2W/mk 40x40x1,5mm
€4.68*
13414 Alphacool Core Thermal Pad Soft 6.2W/mk 120x20x1,5mm
€5.58*
Alphacool's performance thermal pad can be used to cool electronic components of all kinds where... more
Increased service life!
Versatile use!
Technical data thermal pad
Dimensions (L x W x H)100 x 100 x 1,5mm
Thermal Conductivity (ASTM D5470)6.2 W/mK (±10%)
Hardness (ASTM D412)50 (Shore 00) (±15)
Working temperature-50 to ~150°C
Volume Resistance (ASTM D257)1×10¹³ Ohm-m
Dielectric Breakdown Voltage (ASTM D149)6 KV/mm (±10%)
Density (ASTM D792)3.1 g/cm³ (±10%)
Elongation (ASTM D412)50%
Flame Rating (UL 94)V-0
Colorblue
31%
€23.98 * €34.97 *
Content 100 cm² (€0.86 * / 1 cm²)
€86.28 * €119.98 *
48%
Alphacool Core Thermal Pad Soft 6.2W/mk 100x100x2mm
€12.88 * €24.98 *
€2.58 *
46%
Alphacool Core Thermal Pad Soft 9W/mk 100x100x1mm
Content 100 cm² (€0.12 * / 1 cm²)
€11.78 * €21.98 *
Content 24 cm² (€0.23 * / 1 cm²)
€5.58 * €7.98 *
22%
WÄM Alphacool Core Wärmeleitpad Soft 6.2W/mk 40x40x1,5mm
Content 16 cm² (€0.29 * / 1 cm²)
€4.68 * €5.99 *
€1.89 *
€6.49 * €8.98 *
€41.98 *
€39.98 *
Alphacool Aurora LED Flexible Light - Digital RGB 20cm
Content 20 Zentimeter (€69.90 * / 100 Zentimeter)
17%
Alphacool GPU RAM Copper Heatsinks 6.5x6.5mm - 10 pcs.
Content 10 Stück (€1.00 * / 1 Stück)
€26.98 *
€38.98 *
€1.78 *
Delivery date: in 2 - 3 weeks
