Alphacool Ice Layer Thermal Pad - 14W/mK 100x100x0.5mm
  • 12458
  • 4250197124584
  • 0,04 kg
€46.98 *
Content: 100 cm² (€0.47 * / 1 cm²)
Fastening: Slightly adhesive
Thickness: 0,5mm
Surface dimensions: 100 x 100mm
Thermal conductivity: 14W/mk
WAGZ Alphacool Eisschicht Wärmeleitpad - 14W/mK 100x100x1mm
Alphacool Ice Layer Thermal Pad - 14W/mK 100x100x1mm
Content 100 cm² (€0.80 * / 1 cm²)
Liefertermin: in 2 - 3 Wochen
WAGZ Alphacool Eisschicht Wärmeleitpad - 14W/mK 100x100x1,5mm
Content 100 cm² (€1.20 * / 1 cm²)
€119.98 *
WÄM NVIDIA 30 Series Thermal Pad Replacement set
Liefertermin: in 10 - 11 Tagen
PUM Alphacool Core Flat Reservoir 240 Left mit VPP Apex Pumpe
Alphacool Core Flat Reservoir 240 Right with VPP Apex Pump
€189.98 *
Alphacool Y-Splitter 3-Pin to 3x 3-Pin 15cm
€2.48 *
Alphacool fan cable 3-Pin to 3-Pin extension 30cm
€2.28 *
Alphacool Y-Splitter 4-Pin to 3x 4-Pin PWM 15cm
€2.78 *
€6.49 * €8.98 *
RAD Alphacool NexXxoS HPE-30 Full Copper 420mm Radiator
€121.98 *
RAD Alphacool NexXxoS HPE-30 Full Copper 280mm Radiator
€93.98 *
€34.98 *
Content 6 Stück (€4.66 * / 1 Stück)
€27.98 *
Content 330 Zentimeter (€5.75 * / 100 Zentimeter)
€6.99 *
SZ Schlauchabschneider
hose cutter
€6.29 *
