  • 12452
  • 4250197124522
  • 0,06 kg
€34.97 *
Content: 100 cm² (€0.35 * / 1 cm²)
Fastening: Slightly adhesive
Thickness: 1,0mm
Surface dimensions: 100 x 100mm
Thermal conductivity: 11W/mk
WAGZ Alphacool Eisschicht Wärmeleitpad - 11W/mK 100x100x0,5mm
Alphacool Ice Layer Thermal Pad - 11W/mK 100x100x0.5mm
Content 100 cm² (€0.22 * / 1 cm²)
€21.98 *
WAGZ Alphacool Eisschicht Wärmeleitpad - 11W/mK 100x100x1,5mm
Alphacool Ice Layer Thermal Pad - 11W/mK 100x100x1.5mm
Content 100 cm² (€0.50 * / 1 cm²)
€49.98 *
WAR Alphacool Eisschicht Wärmeleitpad - 11W/mK 120x20x0,5mm - 2 Stück
Alphacool Ice Layer Thermal Pad - 11W/mK 120x20x0.5mm - 2 pieces
Content 48 cm² (€0.31 * / 1 cm²)
Alphacool Core thermal pad Soft 9W/mk 100x100x3mm
€49.98 *
Liefertermin: in 2 - 3 Wochen
Alphacool Core thermal pad Soft 9W/mk 100x100x2mm
Content 100 cm² (€0.37 * / 1 cm²)
€36.99 *
WAGZ Alphacool Rise Ultra Soft Wärmeleitpad 7W/mk 50x50x2mm
Content 25 cm² (€0.28 * / 1 cm²)
€6.99 *
WZS Spritzflasche 500ml PE-LD
spray bottle 500ml PE-LD
€4.19 *
Alphacool Core thermal pad Soft 6.2W/mk 100x100x3mm
Content 100 cm² (€0.33 * / 1 cm²)
€32.97 *
€1.89 *
€29.98 *
21%
WÄM Alphacool Subzero Thermal grease 20g
€33.97 * €42.98 *
€6.49 * €8.98 *
€34.98 *
€6.99 *
WAR Alphacool Eisschicht Wärmeleitpad - 11W/mK 120x20x1,5mm - 2 Stück
Content 48 cm² (€0.60 * / 1 cm²)
€28.98 *
WAR Alphacool Eisschicht Wärmeleitpad - 11W/mK 120x20x1mm - 2 Stück
€21.98 *
WAK Alphacool Core Geforce RTX 5090 Reference mit Backplate
Alphacool Core Geforce RTX 5090 Reference with backplate
€199.98 *
