  • 12452
  • 4250197124522
  • 0,06 kg
€23.98 * €34.97 * (31.43% Saved)
Content: 100 cm² (€0.24 * / 1 cm²)
38%
WÄM Alphacool Rise Ultra Soft Wärmeleitpad 7W/mk 50x50x3mm
Content 25 cm² (€0.20 * / 1 cm²)
€4.97 * €7.98 *
44%
Alphacool Core Thermal Pad Soft 9W/mk 100x100x3mm
Content 100 cm² (€0.28 * / 1 cm²)
€27.98 * €49.98 *
33%
WÄM Alphacool Eisschicht Wärmeleitpad - 11W/mK 120x20x0,5mm - 2 Stück PHT EOL
Alphacool Ice Layer Thermal Pad - 11W/mK 120x20x0.5mm - 2 pieces
Content 48 cm² (€0.21 * / 1 cm²)
€9.98 * €14.98 *
49%
Alphacool Core Thermal Pad Soft 9W/mk 100x100x2mm
Content 100 cm² (€0.19 * / 1 cm²)
€18.78 * €36.99 *
45%
Content 100 cm² (€0.18 * / 1 cm²)
€17.98 * €32.97 *
47%
€15.78 * €29.98 *
43%
€3.97 * €6.99 *
31%
WÄM Alphacool Eisschicht Wärmeleitpad - 11W/mK 120x20x1,5mm - 2 Stück PHT EOL
Content 48 cm² (€0.41 * / 1 cm²)
€19.88 * €28.98 *
35%
WÄM Alphacool Eisschicht Wärmeleitpad - 11W/mK 120x20x1mm - 2 Stück PHT EOL
Content 48 cm² (€0.30 * / 1 cm²)
€14.38 * €21.98 *
€1.89 *
21%
€33.97 * €42.98 *
€6.49 * €8.98 *
€6.99 *
