Alphacool thermal pad for NexXxoS GPX 3W/mk 30x30x3mm yellow marked PE Bag (4 pieces)
  • 12196
  • 4250197121965
  • 0,029 kg
€3.78 *
Content: 36 cm² (€0.11 * / 1 cm²)
Area of application:
Graphics card ram cooler
Mainboard voltage converter
North and/or Southbridge thanks to the excellent thermal conductivity
Color: grey
Dimensions (L x W x H): 30 x 30 x 3mm
Thermal conductivity: 3W/mk
electrically non-conductive
Scope of delivery
4x Alphacool thermal pad for NexXxoS GPX
61%
€5.78 * €14.98 *
35%
WÄM Alphacool Eisschicht Wärmeleitpad - 11W/mK 120x20x1mm - 2 Stück PHT EOL
Content 48 cm² (€0.30 * / 1 cm²)
€14.38 * €21.98 *
63%
€1.58 * €4.28 *
43%
Alphacool Core Thermal Pad Soft 9W/mk 120x20x1mm
Content 24 cm² (€0.24 * / 1 cm²)
€5.68 * €9.98 *
Alphacool Core Thermal Pad Soft 6.2W/mk 120x20x1,5mm
Content 24 cm² (€0.23 * / 1 cm²)
€5.58 * €7.98 *
24%
Alphacool Core Thermal Pad Soft 6.2W/mk 40x40x0,5mm
Content 16 cm² (€0.24 * / 1 cm²)
€3.78 * €4.97 *
48%
Alphacool Core Thermal Pad Soft 6.2W/mk 100x100x2mm
€12.88 * €24.98 *
€2.68 *
37%
Alphacool Eisschicht Ultra Soft thermal pad 3W/mk 100x100x1,5mm
€15.78 * €24.98 *
22%
€46.98 * €59.98 *
€1.89 *
50%
Alphacool Apex Soft thermal pad 11W/mk 2x 120x20x1mm
Content 48 cm² (€0.20 * / 1 cm²)
€9.58 * €18.98 *
47%
€15.78 * €29.98 *
62%
WÄM Alphacool Rise Ultra Soft Wärmeleitpad 7W/mk 100x100x0,5mm
Content 100 cm² (€0.05 * / 1 cm²)
€4.88 * €12.98 *
€1.48 *
