Alphacool thermal pad for NexXxoS GPX 3W/mk 15x15x1.5mm red marked PE Bag (24 pieces)
  • 12193
  • 4250197121934
  • 0,022 kg
€3.18 *
Content: 54 cm² (€0.06 * / 1 cm²)
Area of application:
Graphics card ram cooler
Mainboard voltage converter
North and/or Southbridge thanks to the excellent thermal conductivity
Color: grey
Dimensions (L x W x H): 15 x 15 x 1.5mm
Thermal conductivity: 3W/mk
electrically non-conductive
Scope of delivery
24x Alphacool thermal pad for NexXxoS GPX
€0.98 *
€1.19 *
Alphacool Core Thermal Pad Soft 6.2W/mk 120x20x1,5mm
Content 24 cm² (€0.23 * / 1 cm²)
€5.58 * €7.98 *
24%
Alphacool Core Thermal Pad Soft 6.2W/mk 40x40x0,5mm
Content 16 cm² (€0.24 * / 1 cm²)
€3.78 * €4.97 *
37%
Alphacool Eisschicht Ultra Soft thermal pad 3W/mk 100x100x1,5mm
€15.78 * €24.98 *
€1.89 *
50%
Alphacool Apex Soft thermal pad 11W/mk 2x 120x20x1mm
Content 48 cm² (€0.20 * / 1 cm²)
€9.58 * €18.98 *
47%
€15.78 * €29.98 *
62%
WÄM Alphacool Rise Ultra Soft Wärmeleitpad 7W/mk 100x100x0,5mm
Content 100 cm² (€0.05 * / 1 cm²)
€4.88 * €12.98 *
6%
€16.98 * €17.98 *
17%
S16 Alphacool Schlauch AlphaTube HF 16/10 (3/8"ID) - UV Blau 3m (9,8ft) Retailbox 300cm
Alphacool hose AlphaTube HF 16/10 (3/8"ID) - UV blue 3m (9.8ft) retail box 300cm
€14.98 * €17.98 *
