- Article no.: 13015
- EAN: 4250197130158
- Weight: 0,015 kg
The Alphacool Rise thermal paste is aimed at all users who want to get the optimum performance out of their system. With moderate thermal conductivity this electrically non-conductive thermal paste is suitable for high contact pressures and is clearly the favourite when performance and easy application is required.
Application
The application of the Alphacool Rise thermal paste differs from most other thermal pastes due its optimal viscosity. For perfect application of the paste , a plastic spatula (not included in delivery) or similar should be used and a thin film should be applied.
Properties
The Rise thermal paste has a moderate thermal conductivity and is slightly more fluid than other thermal pastes. This helps with the application. The syringe in which the Alphacool Rise thermal paste is delivered has a replaceable screw cap. This prevents it from drying out, as you rarely need the entire 4 grams of paste at once. Furthermore, this thermal paste is not electrically conductive. So if a drop of paste is missed, damage to the hardware is highly unlikely.
| Technical data | |
| Contents | 4g |
| Density | 2,7g/cm |
| Viscosity | 850000cps TF |
| ColorThermal Conductivity | silver/grey |
- Do not get in eyes, on skin, or on clothing.
- Avoid release to the environment.
- IF ON SKIN: Wash with plenty of water.
- Very toxic to aquatic organisms.
- Very toxic to aquatic organisms with long lasting effects.
- Wash gently with plenty of soap and water.
- IF IN EYES: Rinse cautiously with water for several minutes.
- In case of fire: Do not inhale vapors.
Delivery date: in 5 - 6 days
