  • 13097
  • 4250197130974
  • 0,06 kg
€69.98 *
Content: 50 Gramm (€1,399.60 * / 1000 Gramm)
€62.98*
ZSO Alphacool antistatic wrist cuff blue
€4.48*
€14.98*
WÄM Alphacool Apex Soft thermal pad 11W/mk 100x100x1mm
€15.78*
WÄM Alphacool Apex Soft thermal pad 11W/mk 2x 120x20x1mm
€9.58*
13098 Alphacool Apex Thermal grease 100g
€122.97*
The Alphacool Apex Thermal Grease is intended for all users who want to achieve the optimum... more
Application
Properties
Alphacool's Apex Thermal Grease has an extremely high thermal conductivity, making it one of the best performing thermal pastes on the market. Only liquid metal thermal pastes offer better thermal conductivity. The Apex Thermal Grease is delivered in a 50g container with screw cap. The amount of thermal paste is sufficient for several applications and can be stored in the container protected from drying out. In addition, Apex Thermal Grease is non-conductive and non-caustic. If a small amount of paste is spilled during application, damage to the hardware is highly unlikely.
Range of uses
Volatilization Rate (24H@200°C)%less than 0.5
Density (g/cc)3.2 (Test method ASTM D792)
Viscosity (mPa.s)150~200*10³ (Test method ASTM D2196)
Continuous Using Temperature (°C)-40°C to 120°C
Breakdown Voltage (V/mil)250 (Test method ASTM D149)
Thermal Impedance (°C in 2/W)0.1 +/- 0.01 (Test method ASTM D5470)
Max. working pressure (psi)40
Colorgray
Quantity50g
Safety notes
  • Rinse gently with water for a few minutes.
  • In case of fire: Do not inhale explosion and fire gases.
€4.97 *
20%
€3.97 * €4.97 *
21%
€33.97 * €42.98 *
22%
€46.98 * €59.98 *
WAC Alphacool Core 1 LT Black
Delivery date: in 6 - 7 days
Alphacool ES 19" rackmount rails with rail support
€39.98 *
€6.99 *
€3.47 *
€2.98 *
€2.58 *
€2.68 *
