  • 13015
  • 4250197130158
  • 0,02 kg
€5.99 * €8.98 * (33.3% Saved)
Content: 4 Gramm (€1,497.50 * / 1000 Gramm)
€62.98*
ZSO Alphacool antistatic wrist cuff blue
€4.48*
12960 Alphacool Eisbaer Aurora (Solo) - Digital RGB
€69.98*
€6.49*
11955 Alphacool Eisblock Aurora Acryl GPX-A Radeon RX 6800/6800XT Strix/TUF with Backplate
€49.98*
The Alphacool Rise thermal paste is aimed at all users who want to get the optimum performance... more
The Alphacool Rise thermal paste is aimed at all users who want to get the optimum performance out of their system. With moderate thermal conductivity this electrically non-conductive thermal paste is suitable for high contact pressures and is clearly the favourite when performance and easy application is required.
Application
The application of the Alphacool Rise thermal paste differs from most other thermal pastes due its optimal viscosity. For perfect application of the paste , a plastic spatula (not included in delivery) or similar should be used and a thin film should be applied.
Properties
The Rise thermal paste has a moderate thermal conductivity and is slightly more fluid than other thermal pastes. This helps with the application. The syringe in which the Alphacool Rise thermal paste is delivered has a replaceable screw cap. This prevents it from drying out, as you rarely need the entire 4 grams of paste at once. Furthermore, this thermal paste is not electrically conductive. So if a drop of paste is missed, damage to the hardware is highly unlikely.
Contents4g
Density2,7g/cm
Viscosity850000cps TF
ColorThermal Conductivitysilver/grey
Safety notes
Warning
  • Avoid release to the environment.
  • IF ON SKIN: Wash with plenty of water.
  • IF IN EYES: Rinse cautiously with water for several minutes.
  • In case of fire: Do not inhale vapors.
Alphacool Silver Grease 0.5g
€1.19 *
WACZ Alphacool Eisberg AM3 Schaubensatz PHT EOL
Alphacool Eisberg AM3 screw set
Content 4 Stück (€0.37 * / 1 Stück)
€1.48 *
€6.49 *
€51.98 *
Delivery date: in 2 - 3 weeks
40%
43%
€3.97 * €6.99 *
€83.98 *
