Alphacool NexXxoS HPE-45 Full Copper 480mm Radiator
  • 14473
  • 4250197144735
  • 1,876 kg
  • 10
€158.98 *
13305 Alphacool VPP Apex Pump - G1/4 inner thread including Eisdecke D5 - Acetal V.3
€83.98*
€19.98*
€31.98*
€10.98*
12955 Alphacool Eisblock Aurora XP³ Light - Acryl
€36.98*
€12.98*
13042 Alphacool Eisblock Aurora GPX-N Acryl Active Backplate 3080/3090 Gaming/Eagle
€29.98*
For more than a decade, Alphacool has dominated the market with the NexXxoS Full Copper radiator... more
Connection options & mounting
Safety first
Patented screw plugs
Technical data radiator
L x W x H511,5 x 124 x 45mm (+/- 3%)
Quantity of cooling channels28
Material threadsbrass
Threads4x G1/4" IN/OUT & 1x Fill-/Drainport G1/4" (max. 5mm thread length)
Possible fan size120mm
Possible fan assembly4x one-sided / 8x both-sided
Thread size fan mountingM3
Pressure tested0,8 Bar
Fin density16 FPI
Weight1535g
Warranty: 10 years
Alphacool pull saw for acrylic/PETG pipes 35cm
Content 35 Zentimeter (€51.37 * / 100 Zentimeter)
€37.98 *
€26.98 *
€25.98 *
