Alphacool NexXxoS HPE-20 Full Copper 120mm Radiator
- Article no.: RAD
- EAN: 4250197144353
- Weight: 0,398 kg
The NexXxos Full Copper HPE Radiator uses the same materials as previous NexXxos models, but takes it a step further technically. Due to the condensed internal structure, the number of water channels and copper fins could be increased. Thus, a larger volume of water is in direct contact with the cooling fins and the heat transfer is enormously improved. The higher number of fin rows and their shortening also makes much more efficient use of the cooling surface. Comparison tests with the conventional NexXxos radiator have shown that a performance increase of 4.5K is possible when using the HPE radiator. At higher ambient temperatures and higher fan speeds, the performance gap with the normal NexXxoS radiators even increases progressively, reaching a possible performance increase of up to 6K.
Space-saving & flexible to use
The compact slim radiators can be mounted very flexibly in even the tightest cases thanks to their low overall height of only 20mm.
Connection options & mounting
The NexXxoS HPE radiator has one IN and OUT connection with G1/4" threads in the pre-chamber area. All screws for mounting in the case and for mounting the fans are included with the radiator. Additional screws are not usually required.
Technical data radiator | |
L x W x H | 150 x 120 x 20mm |
Material cooling fins, pre-chambers & channels | copper |
Material threads | brass |
Threads | 2x G1/4" IN/OUT (max. 5mm thread length) |
Possible fan size | 120mm |
Possible fan assembly | 1x one-sided / 2x both-sided |
Thread size fan mounting | M3 |
Pressure tested | 0,8 Bar |
Maximum working temperature | 60°C |
Fin density | 19 FPI |
Weight | 290g |
Color | black |
Warranty: 10 years
Farbe: | schwarz |
Anschluss: | 2x G1/4" |
Lamellen: | Kupfer |
Kühlkanäle: | Kupfer |
Gehäuse: | Stahl |
Lüftergewinde: | M3 |
Druckgetestet: | 0,8 bar |
Anzahl Lüfter: | 1, 2 |
Dicke: | 0 - 29mm |
Fins per inch: | 19 |
Lüftergröße: | 120mm |
Abmessungen (L x B x H): | 150 x 120 x 20mm |
