Alphacool Core Geforce RTX 4090 GameRock + Phantom with Backplate
  • 13474
  • 4250197134743
  • 1,97 kg
€99.98 * €199.98 * (50.01% Saved)
€19.98*
ANK Alphacool HF quick release coupling set TPV - Eisbaer compatible - Black
€11.98*
€17.98*
€229.98*
Alphacool's Core product series is characterized by high quality, outstanding performance and... more
- Gainward GeForce RTX 4090 Phantom GS, 24GB GDDR6X (3413)
- Gainward GeForce RTX 4090 Phantom, 24GB GDDR6X (3390)
- Palit GeForce RTX 4090 GameRock OC, 24GB GDDR6X (NED4090S19SB-1020G)
- Palit GeForce RTX 4090 GameRock, 24GB GDDR6X (NED4090019SB-1020G)
Technical data cooler
Dimensions (L x W x H)217,91 x 146,99 x 32,12mm
Material cooler topacrylic
Max working temperature60°C
Pressure tested0,8 bar
Threads4 x G1/4"
Thickness cooler bottom11,3mm
Thickness cooling fins0,4mm
Distance cooling fins0,4mm
Illuminationdigital aRGB LEDs
Power digital aRGB LEDs5V
Number of digital aRGB LEDs11
Colortransparent
Technical data backplate
Dimensions (L x W x H)217,91 x 123,69 x 5mm
Materialaluminium
Awards & Videos
€99.98 *
Content 2 Stück (€15.99 * / 1 Stück)
Content 6 Stück (€3.00 * / 1 Stück)
€29.98 *
SZ Schlauchabschneider
hose cutter
€6.29 *
€6.28 *
Content 240 Zentimeter (€7.91 * / 100 Zentimeter)
€33.98 *
